Sponsored by: Wheel Design
Is there a way
Old Oct 10, 2025 | 10:04 AM
CP's Avatar
CP
Default Is there a way
to change the mode the car starts in before starting the car? I keep forgetting to push the Z button so the car starts in Tour instead of My Mode, which is loud. My garage door points to my across the street neighbor's bedroom window.
Popular Reply
Oct 10, 2025, 10:11 AM
McBeef's Avatar
McBeef
.....and start the car before you open the garage door.
Old Oct 10, 2025 | 10:10 AM
sjw91's Avatar
sjw91
The only modes the car will retain at start in are Tour or My Mode. If you want to start it quieter than Tour, set exhaust to Stealth in My Mode.
Old Oct 10, 2025 | 10:11 AM
McBeef's Avatar
McBeef
Old Oct 10, 2025 | 10:37 AM
patton's Avatar
patton
St. Jude Donor '09
iirc the exhaust valves are open at first start then close in tour ......either start in the garage door down , back it into the garage, go stealth mode EV but a little talk to your neighbor that your are trying can go a long way ,you might even get a " i like it " from them or no big deal
Old Oct 10, 2025 | 10:39 AM
RKCRLR's Avatar
RKCRLR
If you switch to My Mode before you turn off the car then it will restart in My Mode but the initial bark is the same in all modes (when started under the same conditions). The car always starts with the NPP open but will close them after starting if the exhaust is set to Stealth or Tour.
Old Oct 10, 2025 | 11:08 AM
Greg00Coupe's Avatar
Greg00Coupe
I always back in for this exact reason…..and idle with the door down 10 15 seconds too so cold start is over.
Old Oct 10, 2025 | 12:47 PM
Revmanii's Avatar
Revmanii
My '22 retains sport mode. I switched to it from tour about 15 miles or so from getting it home July 2023. I was so impressed with the difference, that I haven't even played with other modes. Doesn't mean I won't, I hope to be driving it and having fun with it for many years..
Old Oct 10, 2025 | 12:56 PM
sjw91's Avatar
sjw91
My 24 doesn't retain Sport. I wish it did.
Old Oct 10, 2025 | 01:00 PM
RKCRLR's Avatar
RKCRLR
That is an undocumented "feature" is some older C8s. It was a carryover from the C7 which would restart in Sport mode.
Old Oct 10, 2025 | 01:47 PM
ems657's Avatar
ems657
I would buy some ear plugs for your neighbors, plus some donuts from time to time. =)
Old Oct 10, 2025 | 01:58 PM
DonC7's Avatar
DonC7
Screw the neighbors
Old Oct 10, 2025 | 02:07 PM
23cpe3lt's Avatar
23cpe3lt
I applaud your thoughtfullness. It's nice to have caring, respectfull neighbors. Anymore, it's the opposite attitude "screw the neighbors". Those attitudes clearly indicate their mommies didn't love them enough so, they don't know how to behave appropriately.
Old Oct 10, 2025 | 02:12 PM
DonC7's Avatar
DonC7
Can’t take a joke. Really 😎😂
Old Oct 10, 2025 | 03:14 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Hold the "start" button without pressing the brake until the car switches to service mode, switch modes to weather (quietest), start car.
Old Oct 10, 2025 | 04:34 PM
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
Took forever to actually get the answer the OP was asking.....
This is the way.
Old Oct 10, 2025 | 06:09 PM
RKCRLR's Avatar
RKCRLR
That will close the valves prior to starting the car but as soon as the car starts cranking over the valves will reopen and be open when the car starts and then close again. This has been documented by a forum member.
Old Oct 10, 2025 | 06:21 PM
sjw91's Avatar
sjw91
I never tried Stealth mode. The name implies that it would be quiet. Seems odd they wouldn't have a quiet start mode for this exact situation.
To Is there a way
Old Oct 10, 2025 | 06:32 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Start it with the garage door closed. If it's too loud to be in the garage when you do that, use the remote start button on the fob. If you shut it off in Tour the valves will close in about 20 to 30 seconds. Even quicker if you shut it off in MyMode with exhaust set to stealth, I think. My neighbors are car guys, but if I'm starting the car early on a weekend morning I do it with the garage closed.
Old Oct 10, 2025 | 06:33 PM
Red Mist Rulz
Yes, it does seem odd. Even worse is that the have the feature on the Z06, but didn't bother to add it to the Stingray. Once GM has your money, they're not going to give you any new feature for free.
Old Oct 10, 2025 | 09:31 PM
C5racecar's Avatar
C5racecar
Start before you open the door, and gag yourself.
Back in, start before you open the door, and gag/smog everyone in the house.
I gave up. Now I hit the start button and the garage door opener at the same time. That is the way it is.
My neighbors know by now that I leave for car shows at 7:00 on Saturdays.
This is a bug in the C8 system. Maybe this is the best thing to light the CATS so they will warm up faster, but it is not user friendly.
All we can hope for is that C9 is improved.
