According to the instructions they state to unplug the charger from the wall and then unplug the charger from the port in the frunk. And then reverse the procedure to plug it back in. Does anyone know why it has to be done that way? Can you just unplug it from the frunk and leave the maintainer plugged into the wall?
As an Electrician by trade I ALWAYS put the maintainer into the car socket before I plug it in. I prefer to have the arc occur at the low amperage, high voltage plug connection rather than have that surge at the car connection.
I have a Corvette Maintainer (CTEK) and 2 CTEK maintainers for the other two cars. They stay plugged into the wall 100% of the time. I use the power outlet in the frunk for the C8 and connections to the battery for the Benzs. been doing this for many years now nary an issue.
I've left mine plugged into the wall long term and just unplug it from the Frunk connector when I want to take the car out. Done it this way with NO issues for 5 years on the C8, and years before that on a couple C7's, etc.... never had an issue.
I follow the instructions as they didn't put that in the manual just because they felt they needed to make the manual longer.
Under some conditions, thought perhaps rare, could arc and cause damage.
I don’t know what the reason for this is but I’ve had tenders on more Harleys than I can remember and always did it this way per the instructions. Never had a moment’s trouble and have had factory batteries last 5+ years. Probably be fine the other way but I figured better safe than sorry, only takes an extra few seconds.
If it actually HAD to be done that way you would be reading horror stories about people who did it the wrong way. I do suspect that their way is a best practice and I connect and disconnect their way but there are failure scenarios with either approach. I suspect you'd need to do the tests to determine failure frequency and consequences and then do the math to really know what was best.
One possible failure - tender has been dropped and not used for 6 months - tender has an internal short - tender is connected to car - tender sends 120v to car before fuse or breaker blows and higher voltage spike as current is interrupted .
I follow the instructions as they didn't put that in the manual just because they felt they needed to make the manual longer. Under some conditions, though perhaps rare, could arc and cause damage.
The concern is controlling the spark of the electrical connection.
The spark occurs when the connection is finalized so plugging it into the wall last means arc is at wall socket.
spark occurs when connection is severed so unplug at wall first
ensuring arc is at desired location is why there is an order of connection/disconnection on jumpers as well. You want that spark at the negative side or terminal
The is the General best practice, avoids shorts and arcing on the car end causing potential damage. My electric golf carts say the same thing.
GM has to protect themselves by being very specific with instructions. They cannot assume anything, hence step-by-step procedures.
As stated many times above, unlikely anything bad will happen by reversing the plug-in sequence.
