Sponsored by: Wheel Design
Remove Small Nick
Old Nov 7, 2025 | 04:23 PM
lpeagle's Avatar
lpeagle
Cruising
Default Remove Small Nick
What is the best way to remove a very small nick on the trunk of my Red Mist Metallic 2022 C8.(See Attachment)
Can I just try and compound it out and if that is possible what is the best compound to use?
Old Nov 7, 2025 | 04:39 PM
hdrider1's Avatar
hdrider1
I see 3 dark spots in the photo you attached. Is that what you call a "nick". Why are they discolored, did some chemical get on the paint?
Old Nov 7, 2025 | 04:47 PM
lpeagle's Avatar
lpeagle
Cruising
I just noticed it yesterday when I washed it, I assume its a nick. This car is garage kept and is only driven to the casino where it is parked by the valet I don't see how any kind of chemical could get on it
Old Nov 7, 2025 | 05:10 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
That doesn't look like a nick to me it is something on the surface. Try some fine clay then a very light polish to start.
Old Nov 7, 2025 | 05:48 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Try a cleaner wax to start and then move to more aggressive cleaners like clay bar.
Old Nov 7, 2025 | 05:53 PM
lpeagle's Avatar
lpeagle
Cruising
Thank You
Old Nov 7, 2025 | 07:55 PM
dvilin's Avatar
dvilin
I agree with others the picture does not look like a nick. If it is a chip/nick you could use drcolorchip to repair it.
Old Nov 8, 2025 | 06:44 AM
Undy's Avatar
Undy
It looks more like a stain, possible from acidic bird poo.
Old Nov 8, 2025 | 10:26 AM
patton's Avatar
patton
St. Jude Donor '09
Run your finger over it ....you can feel a scratch but it looks like a stain . Find out what it is before addressing it even then always remember what mom taught us ......water and mild soap first
Old Nov 8, 2025 | 10:37 AM
pastexpirationdate's Avatar
pastexpirationdate
Might be a good idea to get some pro help. It’d be easy to make it worse.
Old Nov 8, 2025 | 03:35 PM
JIM EVANS's Avatar
JIM EVANS
parked in a parking garage would bet money its iron deposit from condensation on water pipes running thru the garage.. first clay bar then sand with 1000 grit 2000 grit 3000 grit then buff and polish
Old Nov 9, 2025 | 01:01 PM
lpeagle's Avatar
lpeagle
Cruising
I cleaned it with a corvette cleaner I got Amazon and used some car stain remover and it is gone!
Old Nov 9, 2025 | 01:19 PM
cmck0916's Avatar
cmck0916
Looks like a stain on top of the clearcoat. Try Isopropyl alcohol using a microfiber cloth, then mineral spirits if that doesnt work.
To Remove Small Nick
