Maintenance Schedule Visual
updated based on suggestions
Nowhere does the manual say to change the engine oil every 7,500 miles. It says to change the oil when you get the "change engine oil" message on the DIC, but at least once a year (which is actually included in the engine oil life calculation). Its true that the maximum mileage the oil life system will go before indicating a change is 7,500 miles but it can be less.
The transmission fluid is changed when you get the change transmission fluid on the DIC, or 45000 miles, or at least every three years, whichever is first. According to the manual, the transmission fluid life system calculation is based on a combination of factors which include temperature and miles driven [but not time]. Based on driving conditions, the mileage at which a fluid change is indicated can vary considerably. So, it could be less than 45000 miles (although no one has ever reported that).
There is also a transmission filter life system in later models. The manual says the it is based on the number of miles driven as outlined in the Service and Maintenance section. So it is mileage only as shown in your chart.
And, unfortunately folks are confused because (in part) the requirements are actually confusing - particularly the first DCT filter change. Past experience folks have using tabular maintenance schedules is that the service may be performed at the indicated mileage or less. That is no longer true with the first filter change. It must by changed between 7000-8000 miles even if done earlier.
AI Chat says:
"On the Corvette Stingray (C8), the AC desiccant packet is housed inside the condenser assembly. To replace it, the refrigerant must be evacuated, the condenser accessed, and the desiccant bag removed and swapped for a new one."
FWIW I never heard of this maintenance step on a Vette before.
AI Chat says:
The condensers in front of the car where the air inlets scoops area. I found a reference in the Service Manual to the desiccant cartridge, so it may be seperaterly replaceable, but I could not find a procedure for its replacement in the version of the manual that I have. So its either a cartridge in the receiver drier or the receiver drier itself. But not the condensers;
Good points. Thank you. Yes the 7500 mile is to 'check' engine oil and life per the manual- but the oil life monitor or once a year over ride that. Yes- none of this is meant for people to ignore the 'life' monitors. I think of this list as a minimal and you have to look at both mileage and time. It helps me keep it straight, but agree its not perfect.
AI Chat says:
Every 161 000 km (100,000 mi) . Replace hood and/or body lift support gas struts. Or every 10 years, whichever comes first. See Gas Strut(s) 0 269.
My 1980 Toyota pickup (R12) has the original receiver dryer and works fine. I don't think I've ever added refrigerant.
I see what you are saying - that the material itself might break down. And it does mention failure of the desiccant.
Our co-members point out the reason for servicing.
Seems the bag is not serviceable, and is contained in the receiver/ dryer part # 84789220 - price seems to be $29.92.
Wow, not what I would call a do at home project as the freon needs to be evacuated and re-filled.
Oh well 7 years or never
I'm not going to attempt to explain that, but here they are.
