Sponsored by: Wheel Design
oil Pressure
Old Dec 9, 2025 | 08:10 PM
tome's Avatar
tome
Default oil Pressure
I have a 2026 Stingray, and just curious what you guys (gals) are seeing for oil pressure when cruising at say 1500RPM or 2000 RPM. Are you seeing a difference? Mine seems pretty low and doesn't respond/change much when reving/cruising. 31 - 34 is all I'm seeing during the break-in drive yesterday. All the temps seemed normal.
Old Dec 10, 2025 | 05:01 AM
VinnyP's Avatar
VinnyP
You didnt specify whether your in a Z06 or Stingray. i can only answer for Z06. At highway cruise speed and normal temperatures, my oil pressure hovers around 30 psi.
Old Dec 10, 2025 | 10:43 AM
tome's Avatar
tome
Good Point-Fixed with better information
Old Dec 10, 2025 | 11:47 AM
Cjunkie's Avatar
Cjunkie
You have a variable rate oil pump. It is designed to give you the minimum amount of oil pressure needed to cause the least amount of drag to give you the maximum mpg possible. Pretty common on a modern car.
Side note- both my 22 GT500 and 25 Dark Horse would go OVER 100psi at cold idle and driving and then drop to the high 30s hot idle.
Old Dec 10, 2025 | 01:04 PM
Sledge Hammer's Avatar
Sledge Hammer
My 21 C8 has the same oil pressure as you. It is no problem and not like back in the old days when you felt you needed to do a rebuild at these low oil pressures.
Old Dec 13, 2025 | 01:10 PM
Zormecteon's Avatar
Zormecteon
. What he said.
Old Dec 13, 2025 | 11:59 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Modern low viscosity oil and the tight engine clearances don't generate high oil pressure.
Old Dec 14, 2025 | 08:14 AM
Andybump's Avatar
Andybump
The oil used in the Stingray is 0W-40. The 0W means (more or less) that when the oil is cold it has the same viscosity as a SAE 0 oil at a cold reference temperature. The 40 means that when the oil is warmed up in your engine (a reference temperature is also used for that) it will have the same viscosity as a SAE 40 oil at that same reference warm temperature. It is no "thinner" than a warmed up SAE 40.
The oil pressure in the C8 hovers around 30 psi regardless of temperature, or engine rpm because it is very well regulated to be what the engine requires by a variable displacement pump that is computer controlled. Its not that the viscosity of the oil does not "generate" a high oil pressure, it that the C8 engine does not require a higher oil pressure.
Old Dec 14, 2025 | 10:14 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep, like everything else in the C8, Alternator voltage etc it's controlled by a computer NOT the old max pressure bypass spring in meshed gear oil pump. All to reduce wasted energy.
This is Pic from my C7 that had the similar. It's a variable volume pump not just when pressure gets to a limit a spring bypasses oil to the inlet like geared pumps of old! That still wastes energy.
Pic from C7 but C8 engine oil pump is similar. Not the old meshed gear pump with a fixed max pressure bypass spring and passage. It's truly a variable volume pump. So at cursing speeds with modest throttle, where less oil volume/pressure is needed even as rpm increases, the outer pump housing moves, and vanes pump less volume. When needed for WOT high hp it provides more volume resulting in higher pressure. Red shows how sliding vanes move as outer race moves.
Old Dec 14, 2025 | 11:28 AM
tome's Avatar
tome
Well pretty obvious I was worried about nothing, but better to ask than discover I should have paid more attention......
Thanks all for your input.
Old Dec 14, 2025 | 11:38 AM
JerryU's Avatar
JerryU
FWIW if you are looking at the Battery voltage on the dash meter (really the alternator voltage.) Like oil pressure no longer a voltage regulator that limits how high a voltage the alternator could produce. All controlled by a computer! You may see a step change in voltage from ~14 volts when the computer is allowing the voltage to get to 80% battery charge capacity. Then it can jump to 13 volts just enough to power the sound system etc BUT not enough to change the battery past 80%. GM says for fuel economy as changing beyond 80% takes more energy and is not as efficient at charging to 80%. Most car manufactures are doing that to get the best EPA mpg rating!
Old Dec 14, 2025 | 07:40 PM
Warp Ten's Avatar
Warp Ten
The engine oil pressure sensor is located at the output of the oil pump?
Old Dec 14, 2025 | 07:51 PM
Warp Ten's Avatar
Warp Ten
Why I ask about where the engine oil pressure sensor, is the PF64 engine oil filter has a pressure relief valve set to 22 psi. So if the oil pressure at the filter is 30 psi, most oil will bypass the filter media.
Old Dec 14, 2025 | 08:21 PM
Andybump's Avatar
Andybump
No. In quotes is from the Service Manual: "The oil is pressurized as it passes through the primary pump and is sent through the engine block lower oil gallery to the liquid-to-liquid (engine coolant to oil) engine oil cooler. Oil exits the engine oil cooler, past the engine oil pressure sensor, and enters the full flow oil filter where harmful contaminants are removed. A bypass valve is incorporated into the oil filter, which permits oil flow in the event the filter becomes restricted."
But I don't think that sensor alone is what is use to regulate the oil pressure. Oil pressure control is more complex than that.
"An oil passage from the camshaft bearing permits oil flow to the upper rear of the primary oil pump.. Oil is pumped through this passage and provides hydraulic pressure to the first stage oil pressure cavity in the primary oil pump. Hydraulic pressure in the first stage pressure cavity regulates engine oil pressure and can help reduce the load on the engine during normal operating conditions. " In other words its a direct feedback of hydraulic pressure to the pump that regulates the pressure, mechanically. But that's not all. There is also an engine oil pressure control solenoid valve (I think mounted on the oil pump housing somewhere) that also has a role in controlling oil pressure. It is controlled by the ECM "based on Engine Speed, Calculated Engine Oil Temperature, Engine Oil Pressure, Engine Run Time. When the solenoid valve is commanded Off, oil pressure is higher. When the solenoid valve is commanded On, oil pressure is lower"
Old Dec 14, 2025 | 08:26 PM
RKCRLR's Avatar
RKCRLR
The filter relief valve relief pressure is a pressure drop between the inlet and outlet of the filter so it will only relieve when the pressure drop across the filter exceeds that. You can have 60 psi at the inlet and 40 psi at the outlet and it wouldn't bypass.
The oil pressure reading uses ambient pressure as a reference.
Old Dec 14, 2025 | 09:09 PM
Warp Ten's Avatar
Warp Ten
Ahh .. thanks RKCLR .. I see what you mean. The filter would have to contaminated enough to reduce the press on the other side of the media by 22 psi. What the inlet absolute pressure is not relevant. .. I hated fluid dynamics..
To oil Pressure
