Sponsored by: Wheel Design
Configurator anomaly?
Old Jan 17, 2026 | 09:36 AM
rmiked's Avatar
rmiked
Default Configurator anomaly?
I was just configuring a C8 Z51 with Mag Ride on the “Chevy Build and Price” configurator. It will not allow both options. If I select Z51, then scroll down to “performance options”, it deletes Z51 when I add Mag Ride. I can get either Z51 or Mag Ride but not both? Is there any kind of restraint which could possibly preclude both? Maybe something related to the Performance Traction Mgmt software that is included when you select both Z51 and Mag Ride? I have never seen this before.
Popular Reply
Jan 17, 2026, 10:10 AM
MrMik001's Avatar
MrMik001
There are two different mag ride options in the configurator. One for the base car and one for the z51 option. It is confusing but look hard at it and scroll down and you should find the correct one to choose.
Old Jan 17, 2026 | 09:58 AM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
Default ff
Changing the Magnetic Selective Ride Control™ will also change the following:
REMOVED
Michelin® Pilot® Sport 4S 245/35ZR19 front and 305/30ZR20 rear, high performance, run-flat summer-only tires
Aero delete for Z51 Performance Package
Z51 performance suspension
  • Z51 performance suspension
  • Electronic Limited-Slip Differential (eLSD)
  • Performance ratio rear axle
  • Z51 performance Brembo® antilock brakes
  • Performance exhaust
  • Michelin® Pilot® Sport 4S 245/35ZR19 front and 305/30ZR20 rear, high performance, run-flat summer-only tires
  • Z51 rear spoiler
  • Heavy-duty cooling system
Price Change
-$2,660
Old Jan 17, 2026 | 10:02 AM
frankbicknell's Avatar
frankbicknell
I have no knowledge of this process, but my 2023 has Z51 and mag-ride. It was available at one time.
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I found the same in testing the configurator, even the 2025 configurator.
I also Googled: "Is corvette magnetic selective ride control included in z51 package"
I guess the dealers can over-ride and add the Mag-Ride option. You need to add the cost. $1895
Best wishes. Have you look at cars already at dealerships. Good time to buy!
Old Jan 17, 2026 | 10:10 AM
MrMik001's Avatar
MrMik001
Old Jan 17, 2026 | 10:26 AM
Stoopalini's Avatar
Stoopalini
Like Mike said, you have to choose the "Z51 equipped MagRide" option, and not the standard "MagRide" option.
Old Jan 17, 2026 | 11:39 AM
rmiked's Avatar
rmiked
Ok. I guess I didn’t notice the 2 Mag Ride options. I’ll pay more attention. Thanks
Old Jan 17, 2026 | 12:00 PM
V RED 08's Avatar
V RED 08
Default Model Mix
Does anyone know the model mix on the assembly line in 2026?
Old Jan 19, 2026 | 01:23 AM
AdamK47's Avatar
AdamK47
This is true. Selecting the non-Z51 mag ride will ask to remove Z51.
To Configurator anomaly?
