Sponsored by: Wheel Design
Brake squeal
Old Jan 28, 2026 | 12:47 PM
vettebob2's Avatar
vettebob2
Default Brake squeal
Hello,
I've had my 2023 for a few months now and have enjoyed every moment with it.
But...........................
I am getting brake squeal every now and then. Some days it does not and one day it will
It is cold here. highs in the upper 30's or low 40's. Would that have anything to do with it?
As I said it is not a constant thing. Most days it doesn't and then one day it does and then we repeat.
any advise/suggestions. or education for me to learn.
Old Jan 28, 2026 | 12:58 PM
Spamburger_Hamburger's Avatar
That's just what performance brakes do. Put a good heat cycle on them and they'll stop for a while. They are designed to work best hot. There are some other brands of pads you can get that will squeak less also.
Old Jan 28, 2026 | 01:09 PM
papillion's Avatar
papillion
Default Now hear this........
Cold temps are not the norm in Tucson. But when we have mornings in the high 30s low 40s, invariably our brakes will protest till we have gone a ways and stopped a few times. No different with the C6/7 we had.
Old Jan 28, 2026 | 01:34 PM
C5racecar's Avatar
C5racecar
I have not tried this stuff on my C8 because have not had brake squeal yet, but it works great on mountain bike disc.
Old Jan 28, 2026 | 01:55 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by vettebob2
Hello,
If the squeal ours on slow mostest braking just eliminate the cause. Not the Band-Aid dealer will try (using high temp brake lub on the metal steel pad sides ) because they get paid by GM to do it! But doesn't last and not free on a 2023. The cause is spotty brake pad film on the rotors. At light pedal stops that causes slip/slick friction and make the pads rattle, hence the squeal.
Look at your Owner's Manual under tracking GM calls burnishing (most call bedding, you can google.) You don't need the ~25 hard braking from 60 to 10 to 15 mph as it defines to fix. i did it with ~6 or 7. BUT need to find a place to:
  • Go 60 mph and apply the brakes aggressively like 0.8 "g" to 10 to 15 mph DO NOT STOP do not activate ABS.
  • Drive for 1 mile (one minute at 60 mph to let the pad residual formed on the rotors start to bond.
  • Then repeat 6 of 7 times NEVER stopping.
  • Then drive ~5 miles without stopping or hitting the brakes to let them full cool and bond the brake pad material to the rotors.
Note dealer will not do that as there is a safety issue of finding a place to do it only you can control.
For performance pads like the Z51 need to periodically apply the brakes aggressively to maintain that uniform pad material layer (it's also fun.) Pad on pad material is the highest friction, best stops are NOT pad on clean of pad residual rotors.
Old Jan 28, 2026 | 02:13 PM
ktaustins's Avatar
ktaustins
2025 C8 of the Year Finalist - Modified
Is this a Z51??? if so, those brakes are made for HIGH PERFORMANCE, JerryU above gave you good advice and beware his last comment... about every time you take it out you need to be aggressive at least one time.
Old Jan 28, 2026 | 02:50 PM
JVi's Avatar
JVi
Do you have a Z51?
If so, burnish the brakes, otherwise, do not.
https://canadiancorvetteforums.com/t...76/post-244003
Old Jan 28, 2026 | 02:57 PM
5632's Avatar
5632
Change to Power Stop and get even more benefits. You won't have to clean your so much.
Old Jan 28, 2026 | 03:12 PM
JerryU's Avatar
JerryU
Originally Posted by JVi
Do you have a Z51?
Since I don’t Track would never “burnish” or bed pads using the aggressive procedure GM outlines in the Owner’s Manual. That is only where the performance brakes will reach tracking temps. My brakes will never get that hot and finding a place to make ~25 hard braking for 60 mph to 10 to 15 mph without stopping, followed by ~10 miles cooling and never stopping is very hard to fine. Heck even when Tracking they don’t want that braking accelerating. But if brakes are squealing at low speeds be they performance or standard brakes 5 to 6 hard braking, 60 to 10/15 mph allowing a minute between and ~5 miles cooling never stopping is fine for all pads and brakes
Old Jan 28, 2026 | 03:19 PM
JVi's Avatar
JVi
I burnished mine and they have never squeaked after 35K miles.
Old Jan 28, 2026 | 06:55 PM
McBeef's Avatar
McBeef
Some will say "that's what performance brakes do" and I can't accept that. I had a c6 GS w/ significant brake squeal that was solved (eventually) with a new set of rotors at 40k miles. My non-Z51 23 had brake squeal (about 3 months after purchased new) in reverse only, and only on cold days. My non-Z51 26 has a 1000 miles and zero issues. 3 vettes, same location/climate/driver, 3 very different experiences with brake noise.
Old Jan 29, 2026 | 06:43 AM
JerryU's Avatar
JerryU
No Need to Accept, eliminate the probable cause (not using a Band-Aid brake lub on pad steel sides that often is only temporary solution!
Yep performance pads as on Z51, Z06, Grand Sport are more susceptible to brake squeal at low speeds with modest braking pressure. A uniform layer of brake pad material must develope when breaking in the car even with standard brakes. If an uneven layer of pad material develops on the rotors, it causes a type of stick/slip friction, creating high frequency vibration and "probably" the cause of slow speed, modest pressure vibration and squealing!
Google AI supports my personal findings
Yes, properly bedding car brake pads can stop or significantly reduce low-speed braking squeal. Squealing is often caused by new pads improper mating with the rotor; the bedding process transfers an even layer of friction material to the rotor, curing this common noise.
More Google Info:
Yes, achieving maximum braking friction, requires a thin, even layer of friction material to be transferred from the brake pads onto the surface of the rotor. This process, known as bedding transforms the braking mechanism to bond pad material to the rotor (MY NOTE: it's a very thin microscopic layer not visible to the eye.)
Why a Transfer Layer Maximizes Friction:
  • Improved Grip: The adherent transfer layer allows the brake pads to get a better, more consistent grip on the rotor.
  • Optimal Performance: A properly established transfer layer can improve stopping distances by up to 20 percent.
  • Consistency: The thin, even layer acts as a consistent friction surface, reducing brake shudder, noise, and vibration.
MY EXPERIENCE:
  • Stopped my 2014 C7 Z51 terrible slow speed. light braking squeal at started to occur at ~1000 miles.
  • IMO, I was probably too easy on the brakes during break-in.
  • As I have on other cars:
  • Found a place to make 5 or 6 hard brake application (~0.8 "g" not enough to activare ABS) from 60 to 10/15 mph NOT STOPPING
  • Once started NEVER stoping with
  • 1 minute between braking (1 mile at 60 mph) to let some pad material formed on the rotor bond
  • AFTER the last braking NOT stopping driving ~5 miles without ever braking
  • That allows the transfered pad material fully bond to the rotor and solves the slow speed squealing issue
Particularly with performance brakes, you should occasionally brake aggressively from ~60 mph to maintain that uniform pad layer on the rotors. I do frequently; IT's FUN!
Old Jan 29, 2026 | 12:51 PM
hokieZ's Avatar
hokieZ
More Google Info:
MY EXPERIENCE:
Mine squeal too and it’s a non-Z51. Any thoughts on burnishing them too?
Old Jan 29, 2026 | 01:03 PM
chazzf's Avatar
chazzf
Hello,
I'm located in So Cal with a 2024 and when it's in the upper 40's/lower 50's here, brakes always squeal for about first 1/2 mile/mile. Happens without fail, then stops. Sounds bad but wouldn't worry about it.
Old Jan 29, 2026 | 01:10 PM
JerryU's Avatar
JerryU
Sure use what I outlined, won't overheat standard brakes.
Find a place to make 5 or 6 hard brake application (~0.8 "g" not enough to activate ABS) from 60 to 10/15 mph NOT STOPPING
  • Once started NEVER stopping with 1 minute between brake applications (1 mile at 60 mph) to let some pad material formed on the rotor bond.
  • AFTER the last aggressive braking, WITHOUT stopping drive ~5 to 8 miles without ever braking
  • That allows the transferred pad material fully bond to the cooling rotor and solves the slow speed squealing issue
BTW, I do the hard braking on a 4 lane highway leading to an Interstate when there is no traffic. To reduce speed for the Interstate on-ramp I just use the downshift paddle to slow NOT the brakes.
Old Jan 29, 2026 | 01:21 PM
vettebob2's Avatar
vettebob2
Thanks to all and especially 'Jerry U' for the info.
I guess part of my mystery is that I had a Z51 3LT 2015 and it Never did the 'squeal'????
Maybe the 'brakes' were different back then???
Finding a place to do all of the 'prescription' will be kinda difficult ....... but not impossible. I live in the North Georgia.....Mtns......area......but I'll find something, someday.
Old Jan 29, 2026 | 01:41 PM
JerryU's Avatar
JerryU
My 2014 C7 Z51 brakes squealed. Started at 1000 miles. I think i was just too easy on the brakes during break-in. Perhaps as suggested, waiting 500 miles to wear off pad high spots BUT then use the brakes aggressively and that thin uniform layer develops without bedding.
The CCB's on my E-Ray were worse. Not squealing stopping. Up to ~200 miles they were terrible (as many also report with new CCBs.) I bedded at ~250 miles and use ~12 hard brake applications 60 mph to 10 to 15 mph waiting 1 mile between. Found a long, two lane road over the Little and Big PEE DEE River (swapy between so a causeway) that had the required length, few interesting roads so no cars entering to require braking or to interump the miles needed. Than drove without brakes for ~8 more miles using only the downshift paddle to slow were needed. Braking was excellent after that.
Old Feb 2, 2026 | 10:51 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Congrats on your 2023 Corvette. We are happy to have you a part of such an active community here. If the braking squeals ever becomes a concern for safety, we urge you to connect with your local Chevrolet dealership immediately for a diagnosis. You can email us at socialmedia@gm.com with your forum username in the subject line, if you ever need assistance with this.
To Brake squeal
