I traded my 2023 for a 2026 and i'm frustrated with the positioning of the HUD. I adjusted the HUD positioning with my programmed seating. I thought the HUD would always be in the same memorized position when I started the engine. It requires adjustment each time i use the car. My old Vette never had this issue. Is there something I'm missing? Thanks for any insight you may provide.
I have a 2026 and have not noticed this problem. Did you try re-saving your memory seat positions after adjusting the HUD?
Thanks to all for making the HUD position itself to a programmed setting. I noticed the HUD would stow itself in the uppermost setting. I was able to reset the seat memory after adjusting the HUD position to a perfect viewing position. Thank you all for your quick response.
For the first 2 weeks the HUD moved below my sightline every time I started the car. It finally went away and stayed in position. Now it's fine. Now I have to contend with %100 brightness that never dims.
