Three year trans service
Does this make any sense other than more profit for the dealership? Just asking
I’ve tried to buy my last three Corvettes there and never any success.
That's a lie from your dealer. GM is NOT telling dealers this info.
Time to move on to a reputuable business owner.
https://www.corvetteworlddallas.com/...ls/service.htm
Supplying your own GM approved materials, such as ACDelco DCTF-FFL-4 for the fluid change, is of course not a warranty issue. But there is an interesting subtlety. If supplied by the customer and installed by the dealer, the dealer will (based on posted invoices) often indicate on the service invoice that the transmission fluid was customer supplier, and they may even state the type of fluid. But missing from the dealer record will be a receipt for the fluid - no "billing". So - if a problem arises, GM might ask for receipts, which the customer can, or course, supply if needed.
Are receipts required? I don't think so. Its true that in both the owners manual and warranty manual, receipts are recommended, but are they required?....The factory warranty manual appears to say no they are not:
"Owner's Warranty Responsibilities
As the vehicle owner, you are responsible
for the performance of the scheduled
maintenance listed in your Owner’s Manual.
GM recommends that you retain all
maintenance receipts for your vehicle,
but GM cannot deny warranty coverage
solely for the lack of receipts or for your
failure to ensure the performance of all
scheduled maintenance."
and also
"Receipts and records covering the
performance of regular maintenance or other
repairs (such as those outlined earlier)
should be retained in the event questions
arise concerning maintenance. These receipts
and records should be transferred to each
subsequent owner. GM will not deny
warranty coverage solely on the absence
of maintenance records. However, GM may
deny a warranty claim if a failure to perform
scheduled maintenance resulted in the failure
of a warranty part."
And, in the Owners Manual:
"Keep a record with all parts receipts and list
the mileage and the date of any service work
performed. See Maintenance Records"
"After the scheduled services are performed, record the date, odometer reading, who performed the service, and the type of services performed in the boxes
provided. Retain all maintenance receipts."
Bottom line: the dealer's reason for not installing customer supplied fluid was wrong, like everybody said. But yes, the dealer can refuse to use customer supplies material. All that said, when supplying your own fluids and parts to a dealer, keep the receipts for those parts, just like you would if you did the work yourself.
