Sponsored by: Wheel Design
PDR SD card?
Old Apr 7, 2026 | 09:43 PM
mpr3369's Avatar
mpr3369
Default PDR SD card?
What is everyome using for the PDR SD card? Is there a specific one that is required or recommended? I plan on running it all the time essentially like a dash cam. Thanks for any info. I appreciate it.
Old Apr 7, 2026 | 09:59 PM
Ruz's Avatar
Ruz
This is what I am using…
Amazon Amazon
RKCRLR's Avatar
RKCRLR
Get a high endurance card, like those intendd for dashcams and security cameras. The minimum class is in the owner's manual but just about any modern quality will exceed it. Exceeding the class requirement only helps when downloading information from the card onto a computer. And be aware that there a lot counterfeit cards out there.
Old Apr 8, 2026 | 07:29 AM
mpr3369's Avatar
mpr3369
Thanks for the replies. I was leaning towards a Sandisk.
Old Apr 9, 2026 | 01:58 PM
MKC8's Avatar
MKC8
Be careful about using some Sandisk and other SD cards with built in firmware encryption.
I'm pretty sure the encryption might be a problem.
Old Apr 9, 2026 | 02:00 PM
mpr3369's Avatar
mpr3369
Hopefully not. I already ordered a Sandisk. If I reformatted the sd card would that help?
Old Apr 9, 2026 | 02:07 PM
MKC8's Avatar
MKC8
It might. I haven't tried one in my car, in original format or reformatted.
There is usable disk space on the card besides the encryption stuff, so it may work right out of the box.
Try it, and let me know?
I'm using (I think) a Samsung high capacity class 10 card I got on Amazon.
Old Apr 9, 2026 | 02:13 PM
mpr3369's Avatar
mpr3369
When it comes in I'll try it out & post up about it.
Old Apr 9, 2026 | 08:04 PM
Ruz's Avatar
Ruz
I never did anything with mine, put it in and it recognized it instantly. 👍
Old Apr 9, 2026 | 10:14 PM
MKC8's Avatar
MKC8
Delete
Old Apr 10, 2026 | 05:54 PM
mpr3369's Avatar
mpr3369
Well got my sd card today. Installed it. No issues at all. There's a picture attached of the sd card I bought.
Old Apr 10, 2026 | 08:14 PM
MKC8's Avatar
MKC8
Does that card come with built in encryption? I think not, so it should work right out of the box.
Even if it does, you're not using it, so good stuff.
Old Apr 11, 2026 | 12:47 AM
Arizona Jim's Avatar
Arizona Jim
Default SD card
Read the owner manual. It spells out exactly the type of SD card to use.
Old Apr 12, 2026 | 12:27 AM
AdamK47's Avatar
AdamK47
I use a SanDisk 512GB Extreme PRO.
Had a bit of a problem first using it. Put it in straight from the package without formatting it. The car saw it and I tried to format it from the car. It disappeared right after that. Couldn't see it again. Took it out and formatted it on my laptop in exFAT format. Still didn't show up. Decided to give up for the night and left the SD card still plugged into the car.
The next morning, I tried it again and it showed up. Not sure if it was a 2026 bug. Letting the car sit overnight reset something and it worked afterwards.
Old Apr 12, 2026 | 08:42 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
AND buy from a know quality source! Over half the devices of this type on Amazon are Bootleg. I had the issue with my top brand name SanDisk USB Flash Drive AND the PDR SD Card bought from Amazon. For the SC Card it was not overwriting once filled.
Bootleggers are smart. They copy the Top Brands!
Old Apr 12, 2026 | 08:47 AM
JerryU's Avatar
JerryU
From Google AI, paraphrased:
Counterfeit flash drives and SD cards are highly prevalent on Amazon, with estimates suggesting could be ~50% of listings in high-value categories, including memory products, could be counterfeit.
  • How to Avoid: Purchase only from "Sold by Amazon, Shipped by Amazon.com" or verified official brand stores.
IMO, not foolproof way to avoid. I have found buying batteries with Amazon name, may not be counterfeit but fail open in short time. Perhaps buying from "official Brand store" may work.
Old Apr 12, 2026 | 01:46 PM
MKC8's Avatar
MKC8
Maybe the PDR had trouble reading the VTOC/sector map on a card that big?
I doubt GM put or chose state of the art processor/RAM/ROM in the PDR system.
The 2024 OM says " exFat formatted, class 10 SD card, minimum size 16GB" on page 131.
Your card is half a terabyte.
To PDR SD card?
Old Apr 13, 2026 | 12:34 PM
BreakLikeTheWind's Avatar
BreakLikeTheWind
I have a 64GB SD card in mine, but it will not overwrite once full. Is it because of the card or is there another issue since I have that option enabled in the PDR?
Old Apr 13, 2026 | 12:40 PM
RKCRLR's Avatar
RKCRLR
Make sure the write protect tab isn't enabled on the SD card.
Old Apr 13, 2026 | 01:24 PM
BreakLikeTheWind
If it was enabled, it wouldn't record anything at all.
