Have looked the owner's manual from front to back and cannot find how to set up for launch control. Can someone please advise me how to set it up step by step? Plan on using it just one time to see what my car will do. Thanks for the help. Car is a Z51 2022 HTC.
Also look at the section under Dual Clutch Transmission / Double Paddle Declutch / Rapid Exit
Basically you pull both paddles, fully press accelerator and quickly release both paddles and hold on.
For extra fun turn off Traction Control (TCS) and you can burn off a hundred dollars of rubber and fuel.
Make sure you have a lot of room because the car will squirm without TCS
