Sponsored by: Wheel Design
C8 Corvette shear plate modification
Old May 6, 2026 | 08:02 AM
frankbicknell's Avatar
frankbicknell
I also wonder if there is any engine compartment cooling gained.
Old May 6, 2026 | 09:30 AM
JimB.'s Avatar
JimB.
Nicely done! Thank you for the detailed instructions and measurements.
Old May 6, 2026 | 10:56 AM
V Vette's Avatar
V Vette
Originally Posted by Spare seat
A piece of cardboard shaped and placed will help eliminate any splash that occurs while pulling the filter or drain plug.
As in post 11 Thanks
Old May 6, 2026 | 10:08 PM
planojoe's Avatar
planojoe
I just used some medium grit sandpaper to smooth out and round over the edges. I also knocked off the sharp edges on the engine oil opening that was left sharp.
I went back and forth using a drill press. You can sense when they get paper thin and then the one side took out the other when I went all the way through.
Thanks for the info.
