Z51 ceramic brake pads
I like the Snap-On business model BUT it means high prices! Bought the 10 point socket a forum poster said fit - from Amazon. Same one used on Porsche Cayenne, Audi SUV brake calipers. Paid $16 delivered in 2 days. Saw the same one on eBay for ~$10 but directly from China shipped in ~3 weeks.
However, IF you remove the center bolt so you don't have to remove the caliper to remove the pads you'll have to deal with the strong double sided tape that holds the pads to the pistons. I had similar tape on my early 2014 Z51 front brakes (note not used after ~ mid 2014.) Unlike the video where he broke the bond by putting the tape in tension, I could not get the pads to budge leveraging upward with the tape to piston being held in shear! My method was to use a stiff paint scraper and hammer as shown below (took a lot of force
PIC Left From My Early 2014 Z51 Pad Install PDF.
That Nut is NOT Because of High Torque. Reportedly comes out easy as it just prevents the calipers from spreading.
That's a pic of what I bought. Same one from Amazon that a poster said fit! It does not give a mm size. It is also used on the Cayenne, VW and Audi equivalate SUV. Can buy a bit cheaper from China via eBay but wanted to get what he said fit! $16.
Don't have my C8 yep BUT like I did on my Grand Sport will have low dust pads purchased before it arrives so I can change pads day 1 and not have to clean the rotors of OEM brake pad residue.
Still waiting to see a comment about how someone who removed the center pin got the pads unstuck from the high temp piston to pad tape.
The same tape was used on the early 2014 Z51 front pads. Mine was built in September 2013. Later 2014's did not use the very strong two sided brake tape. When I changed my pads the solutions suggested were not easy, like a hack saw blade etc. Tried a solvent, no help. Finally sharpened a stiff paint scraper and used a hammer. But took a lot of force. Not sure a heat gun will help as you can look up the specs and the one 3M sells can handle very high heat!
Will be interested to see what is reported.
Many research results indicate that copper has a good ductility, which is conducive to the formation of stable, continuous and uniform friction transfer film on the counter surface, and plays a role in stabilizing the friction coefficient and reducing wear loss.
SSB 6557 adopted in Washington State in 2010 limits the amount of copper that is allowed to be used in friction materials, to be eventually phased out to trace amounts, due to the negative impact of high copper levels on aquatic life.
Drilled and slotted rotors make more noise, more dust, wear pads faster, retain dirt and water in the grooves, are more expensive, are very tough to re machine.
Therefore, GM couldn't use copper pads and therefore chose not to use drilled/slotted rotors on the 2020 Corvette.
Think you meant the reason for the C8 using solid and not slotted and drilled rotors is the lower cost!Also on my prior C6 Z51 and C7 Z51 and Grand Sport slotted and drilled were mostly (if not all) for "BLING!"
Not using them on the C8 has nothing to do with copper free pads, IMO! Investigated Copper and Iron possibly causing "rotor browning. " It's probably more excess Iron contaminant in a raw material. This is part of what I found:
Why Copper Free Brake Pads:
"Why do some pads use components that could be considered harmful to the environment? Part of the answer is that some materials effect on the environment were not fully realized until a few decades ago.
Two states have legislation limiting its overall content in brake pad formulations. The main focus of new laws in Washington state and California revolves around protecting the environment. Studies have shown 35 to 60% of the copper in water run-off is caused by brake dust! Much of the dust that is emitted into the air is blown onto areas next to the road, or is washed into the storm drains when it rains. Most storm drains flow directly into creeks, rivers and marine waters without wastewater treatment. Copper and other harmful materials can hurt and kill small marine animals and even render some fish without a sense of smell.
Marine Invertebrates:
Invertebrates, which represent more than 95% of the known species on Earth, are animals without backbones. They are diverse, interesting, colorful, and unusual, marine life. In invertebrate marine life, copper alters their biochemical and biophysical properties even at very low concentrations. Water with even 0.018 ppm copper can be toxic to some invertebrates. In California and Washington, brake pads in 2025 must have less than 0.5% copper.
Benefits of Copper: Despite its drawbacks, copper performs several functions: It adds structural integrity to the brake pad material, reduces fade so that brakes remain effective through extended braking events, transfers heat efficiently, and helps brakes be more effective in cold weather. Copper also has properties that help prevent brakes from squeaking and shuddering.
Brake pad manufacturers are finding other materials to provide those braking properties. For example, Stainless Steel Swarf (small chips, turnings of SS) can replace copper with similar performance. Some have already introduced “copper free” brake pads, including Bendix, Bosch, Brembo and Hitachi who state: “we have developed “copper free” brake pads with a stable friction coefficient by substitution of materials that perform the thermal conductivity and lubricating priorities with improvement in the change in friction surface.
My Experience With Iron Contamination:
Iron contamination of the brake pad raw materials could be a cause of the brown rotors. While managing in a welding materials R&D laboratory in Ohio I passed an open pit mine of a material we used in some of our welding fluxes. It was on the way to the Drag Races in Thompson Ohio, it was sand! The company we purchased from had various grades they sold at different prices. The highest grade was sold to folks making silicon commuter chips; it had very low iron content. Iron is a contaminant in the silica sand. In welding, it can influence the flux performance so we purchased a low residual content product that had low iron. We paid more than the “sand” they sold for concrete etc. that was a brown color.
When I passed this very large open pit mind you could see areas of pure white sand and the more common brown sand. We purchased product with a guaranteed maximum iron and other unwanted containments. As we did with all steel welding wire that came into the plant we checked the chemistry of the sand and other ingredients. That is the cost required to make a quality product. In fact, we were delivering some of these products to weld 10-inch-thick Nuclear power vessels and Nuclear submarines.Recent Info, Copper free Pads:
Brake manufacturers have developed new, low-copper and copper-free brake pads. Many of these new reduced-copper and copper-free friction materials actually perform better than the last-generation friction materials they replace. Improvements include better stopping power, improved wear resistance, and reduced dusting and noise.
Latest Copper Free Pad Info:
Finding ways to reduce copper in existing friction materials led to new ways to improve overall braking performance. Thus, consumers get not only a new generation of environmentally-friendly friction materials but a significant step-up in braking performance. Most consumers who have had the new reduced copper pads installed on their vehicles report a noticeable improvement in how well their brakes perform. Repair shops are also seeing fewer comebacks.
One solution replaces Copper with by Stainless Steel Swarf (stainless chips from machining etc) in the brake-pads. In tests adding 5 to ~10% SS swarf showed performance properties of brakes pads, including wear resistance improved significantly with higher levels."
Agree with your conclusion, to get low dust IF not Tracking use ceramic pads designed for Street use.
FWIW, zinc does something similar. That's what no mildew a short distance below galvanized flashing around a skylight etc. We bought roof shingles that have zinc included in the asphalt gravel mixture!
As for the sqeek, did you install the backing shims?
Hopefully you 2nd post will be good news!
Pic below is the ceramic brake pad lub I put on the Carbotech pad backs and not a peep in 8 years of C7s and 2 years with my C8.
