Sponsored by: CARiD
CPR installed Fabspeed test pipe with dyno video
Old May 29, 2020 | 10:53 PM
Cordes Performance Racing's Avatar
Supporting Vendor
Default CPR installed Fabspeed test pipe with dyno video
Here is the latest video with us tearing down the C8 and going through all the little area's on the car to find out what we see. Yes we are goofballs at times but we just love what we do and enjoy finding new stuff. At the end is the dyno portion with sound clips so if that's all you care about feel free to skip ahead.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old May 30, 2020 | 01:12 PM
Mr_Desmo's Avatar
Mr_Desmo
Sounds great! Looking at the air fuel on the dyno sheet i can see that the test pipes leaned out the ratio substantially from 11.5 to a perfect 13 to 1. Will the ecu bring back the air fuel ratio to 11.5 to one over a period of time? If you tune the stock car to the same leaner 13/1 and add test pipes and correct the tune; what kind of gain are we looking at?
Old May 30, 2020 | 01:35 PM
Supporting Vendor
Sadly we cant tune them yet. We will revisit the dyno and see if afr changed after awhile to know if pcm auto corrected.
Old Jun 2, 2020 | 03:22 PM
RapidC84B's Avatar
RapidC84B
Man that sounds awesome.
Old Jun 2, 2020 | 05:33 PM
azvrod's Avatar
azvrod
Joe and NicD doing their thing! Joe did that thing pick up 30HP and TQ just with a cat delete?
Old Jun 2, 2020 | 05:53 PM
Supporting Vendor
Originally Posted by azvrod
Joe and Nick doing their thing! Joe did that thing pick up 30HP and TQ just with a cat delete?
sure did! pretty wild
Old Jun 12, 2020 | 11:20 AM
vetteandv's Avatar
vetteandv
So did these throw a check engine light? Has the car been driven much since they have been installed?
Old Jun 12, 2020 | 11:54 AM
Supporting Vendor
it did throw a light. we will work on another solution however.
Old Jun 12, 2020 | 09:40 PM
Brandon619's Avatar
Brandon619
Some Kooks headers and a cat delete with an exhaust would be 🔥
Old Jun 13, 2020 | 04:05 PM
Shokosugi's Avatar
Shokosugi
What’s the lead time on ur valved full exhaust and cats? Also how would you compare the sound and volume of the valved setup when open v. Your x pipe?
Old May 16, 2021 | 01:02 PM
MarioC8's Avatar
MarioC8
Not much info on test pipes out there. Did the afr normalize afterwards? If so, does hp drop back down?
Old May 17, 2021 | 12:56 PM
Supporting Vendor
this car never made it back on our dyno. but the others we have done we have tested post install and the HP gains remained.
Old May 17, 2021 | 01:39 PM
MarioC8's Avatar
MarioC8
Awesome, and are these afr changes anything to worry about? I came from an Evo where afrs are everything, but it seems like these v8s are a bit more flexible in that regard.
Ill probably install an O2 spacer to get rid of the Check Engine Light. And will hope that the smell isn’t too bad...
Thanks for the feedback
Old May 17, 2021 | 02:28 PM
Supporting Vendor
the oem widebands correct it nicely. stock cam you won't smell much.
Old May 17, 2021 | 03:27 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Only true test is after a the trims get readjusted with a hour or two of driving. Please recheck after road test. If results repeat, great. Looking forward to the rest of the story.
Old May 17, 2021 | 03:39 PM
itsonlyairandfuel
Also suggest you google C8 lift points, your rear point are too far forward according to
Old May 17, 2021 | 04:22 PM
MarioC8's Avatar
MarioC8
Originally Posted by itsonlyairandfuel
Also suggest you google C8 lift points, your rear point are too far forward according to https://www.youtube.com/watch?v=vMgh9OcOsVU&t=73s .
I believe they commented on youtube that they tweaked that off-camera.
Old May 17, 2021 | 04:32 PM
itsonlyairandfuel
Just looking to help, keep them out of trouble. never made it to the end of video. Just watched the the wiggle test. Really hoping they do a confirmation of AF ratio.
To CPR installed Fabspeed test pipe with dyno video
