Sponsored by: CARiD
Fuse Panel
Old Aug 31, 2020 | 12:11 PM
C8-Vette's Avatar
C8-Vette
Default Fuse Panel
How do you get to the fuse panel, the one that is between the seats ? Owners manual is no help
Old Sep 1, 2020 | 09:51 PM
C8gman's Avatar
C8gman
Pop off the silver top where the speaker is mounted with upward force. Disconnect the speaker wiring harness so you can put the top (silver) piece out of the way.
Then the center piece that sits below that can be pulled out directly towards the front of the car. I believe it's either four or six metal clips that hold it in place.
It does take a little force. Not really an easy access design.
Sorry I don't have any pics but I have done it once to get to a 12V source.
Old Sep 14, 2020 | 04:45 PM
RussM05's Avatar
RussM05
Some where on the forum is an excellent video.
Old Sep 23, 2020 | 03:44 PM
CP's Avatar
CP
There's a 12V source under the glove compartment.
Old Sep 23, 2020 | 03:50 PM
RussM05's Avatar
RussM05
Yes I know. I tried that first but wasn’t able to figure out how to access the wire to the cigar lighter. I was able to remove the glove lid and access the fuse block behind it but getting to the cigar lighter wire proved impossible. Also, I wasn’t able to determine which circuit was switched on that fuse block using my DVM. Sorry.
To Fuse Panel
