Sponsored by: CARiD
Green ring inside tachometer
Old Sep 9, 2020 | 07:52 PM
rv3flyr's Avatar
rv3flyr
Default Green ring inside tachometer
What is the green ring that illuminates inside the tachometer while in 1st gear? It seems to light up around 2500 rpm or so. I haven't seen it in other gears. Could it be a shift indicator?
Old Sep 10, 2020 | 11:41 AM
Gotcha's Avatar
Gotcha
Yes, the green ring is the start of sequential shift lights.
Bring the rpm's up and more rings will light up, yellow and then red...
Have Fun
Old Sep 10, 2020 | 11:46 AM
rv3flyr's Avatar
rv3flyr
Great. I'm still in the break-in mode, so haven't had the rev's up very high. Thanks for the explanation.
Old Sep 13, 2020 | 01:13 PM
StickerDick's Avatar
StickerDick
Yep... after break-in... test it out... the lights come up in every gear change if you push it hard enough,, maybe not in 7th or 8th, but of the others you will see it.
Old Nov 19, 2020 | 11:28 AM
Keiffer's Avatar
Keiffer
so shift at green? Or red?
Old Dec 2, 2020 | 10:57 PM
Joe K Show's Avatar
Joe K Show
Yeah...I’m a little confused by the shift indicator lights. It seems as though you have to redline the car before any shift indicator circles come up...does that sound correct? I feel like I’ve really revel the RPM’s and not seen the circles display at all...anyone else? Also, are you supposed to shift right at the point of the green circle illuminating?
Thoughts would be appreciated!
To Green ring inside tachometer
