ARH Header Install
Took me and a buddy 2.5 Hrs. to install. I did not lift the car up or take any wheels off.
First Disconnect the battery.
Then remove the strut tower braces. 4 T40 bolts and a push pin underneath holding the mag ride wiring. Pass side also has 2 clips for an EGR line I believe.
I used a fuel disconnect tool and undid the EGR line on the Pass side for more room.
Remove 4 heat shields on each manifold. 3 10mm bolts on 3 shields and two on the last one. 11 total 10mm bolts
Remove 3 15mm nuts holding the manifold to the cats. You will reuse them.
Also disconnect or remove O2 Sensor. You will need an O2 Socket as a wrench will not work.
Remove spark plug wires from plugs and 5 13mm bolts holding the manifold to the head and it will come right out.
Add clamp on pass side to keep coolant line away from headers
Install in reverse order.
Install Heat Shield on fuel line and EGR line.
Videos Coming Soon!
https://imgur.com/61LkrIQ
Rev Up
https://imgur.com/h5mp1NE
Drive By
https://imgur.com/BKLri7b
What I'm looking for since I already do get extra sound with my FabSpeed HJS high flow cats, say a 5 on a scale to 10.
Honestly pretty disappointing. I forget what HP they are claiming, but it sure as hell doesnt show itself on track at all.
From others i have talked to they had an issue with too much heat in the engine bay making the review camera cut in and cut out (i guess that would only impact 2LT and 3 LT owners),
