Sponsored by: CARiD
TPMS relearn tool
Old Mar 3, 2021 | 05:51 PM
Ophthos's Avatar
Ophthos
Default TPMS relearn tool
Does the C8 use the same TPMS relearn tool as other GM cars? I have a 2017 GMC Yukon and I want one tool that does both.
Old Mar 6, 2021 | 11:54 AM
C8-Vette's Avatar
C8-Vette
Yes, but the c8 will learn on its own. You can use the relearn tool, but read the owners manual about self relearning
Old Mar 6, 2021 | 02:35 PM
Ophthos's Avatar
Ophthos
Thanks. Don't have my C8 yet. 520 on MacMulkins list. I just need one for my GMC Yukon and was wondering. Nice to know It will relearn on its own.
Old May 12, 2021 | 07:39 PM
Silver31581's Avatar
Silver31581
I think this only applies to the original TPMS sensors. I have a C8 with a new set of track wheels with new sensors. It didn't self learn unless there's a step I'm missing...
Old May 13, 2021 | 08:21 AM
progtp's Avatar
progtp
I put new wheels on mine with a second set of GM sensors and it relearned on its own. I did nothing to calibrate the new sensors.
Old May 13, 2021 | 04:45 PM
Silver31581
My problem was probably not using OEM sensors...
Old May 13, 2021 | 10:06 PM
john91498's Avatar
john91498
I did the same. I even got an e-mail from On Star stating all my tires were flat.
Old Jul 26, 2021 | 02:58 PM
JScottH3's Avatar
JScottH3
My C8 (1300 miles) has lost its TPMS. When I try to get tire pressures, all I get is a Relearn button. I press it, and it says to hold it for 5 seconds to start the learning process. When I do, it just reverts to the Relearn button. Once it tried to start, but stopped after about 15 seconds. Does anybody have any suggestions, other than take to my dealer? Thanks.
Old Jul 26, 2021 | 03:04 PM
rpiechowski's Avatar
rpiechowski
New sensors need to be activated/ programmed prior to being mated to the vehicle so they show an individual id number. Most dealers or tire stores have the activation tool to do this so they can use aftermarket sensors.
Old Jul 28, 2021 | 09:02 AM
Rapidblux2's Avatar
Rapidblux2
Default Learning suggestion
If you use aftermarket Tpms sensors and they are even programmed and your c8 won’t relearn them try lowering the tire pressure below 10 pounds . I use Autel Mx on my track rims and that is what I had to do I also own the programming tool.
Old Jul 30, 2021 | 08:42 AM
dfettero's Avatar
dfettero
Default Latest Gen TPMS?
Are they the latest generation OEM GM TPMS or some Off the shelf?
Sensor GM 13538760
Nut: GM 13581557
Old Feb 10, 2022 | 10:29 PM
Faste60's Avatar
Faste60
The 2022 TPMs have a new sequence and the old tool won't work and the procedure in the owner's manual doesn't work. I have to take mine to the dealers to marry my new wheels to the car.
Old Feb 13, 2022 | 02:59 PM
Foehammer's Avatar
Foehammer
Can anyone else confirm the above? If this is true, then when I install my aftermarket wheels and second set of TPMS I have to go to my dealer? What a mess.
Old Feb 13, 2022 | 04:52 PM
Rapidblux2's Avatar
Rapidblux2
Just bite the bullet and buy an autel scanner or at least there tpms tool
these days not have a good scanner is just plane silly. I have the autel mx808
job tools $385. Thing does everything even abs bleeding .
it’s like when you really start tracking and finally buy a set of scales and go
why the hell did I wait so long ???
Old Feb 13, 2022 | 05:12 PM
Faste60's Avatar
Faste60
The tool that works on my 2018 Equinox doesn't not work on my C8. My local mechanic told me his up-to-date 2021 fancy tool won't work on 2022 cars. I'm taking mine to the dealer on Thursday. New Frequency I miss typed.
Old Feb 14, 2022 | 08:10 PM
GTUnit's Avatar
GTUnit
There is a $5 tool on eBay that works.
Old Feb 14, 2022 | 09:54 PM
Faste60's Avatar
Faste60
Got the part number?? It works on a 2022? Even my mechanics doesn't work and needs an update.
To TPMS relearn tool
Old Feb 15, 2022 | 12:54 AM
metomwhhou's Avatar
metomwhhou
Here's one:
EL-50448 TPMS Reset Tool Relearn Tool Auto Tire Pressure Sensor For GM Vehicles
Old Feb 15, 2022 | 08:28 AM
Rapidblux2's Avatar
Rapidblux2
https://www.jbtools.com/autel-ts408-...IaAlwzEALw_wcB
this is a real tpms tool Get a scanner. It will pay for itself
https://www.jbtools.com/autel-mx808-...t-usa-version/
Old Feb 15, 2022 | 10:10 AM
GTUnit's Avatar
GTUnit
Im not sure but for the price of a Starbucks coffee its a roll of the dice I was willing to take.
I bought a set of the generic ebay EZSensor made bySchrader. They came with the $5 tool. Im not sure if the car just picked them up on its own or if the tool enabled the relearn but they work. Im getting a set of GM sensors for my 3rd set of wheels.
EDIT: All 4 EZSensors stopped working/reading. Guess I'm buying factory GM sensors.
