Sponsored by: CARiD
Does the C8 have a maintenance mode?
Old Mar 20, 2021 | 04:12 PM
cbacejr's Avatar
cbacejr
Default Does the C8 have a maintenance mode?
I had by wheel alignment set to the track settings today and the mechanic had difficulty setting up the equipment. I believe the car was in neural and lifted off the tires. He put the alignment device on a rear tire and tried to turn the tire. As soon as he did this the parking brake engaged. Is there a 'mode' the car can be placed in to prevent this?
Old Mar 22, 2021 | 09:58 AM
cbacejr's Avatar
cbacejr
Can anyone confirm this info?
  • Ignition ON — Engine Running.
  • Apply the brake pedal.
  • Open the door.
  • Shift to Neutral.
  • Release Parking Brake.
  • Turn off the engine and release the brake pedal.
  • The indicator should continue to show N. If it does not, repeat steps 2–5.
  • Exit the vehicle and close the door.
Old Apr 21, 2021 | 06:54 PM
Darryl Berry's Avatar
Darryl Berry
I believe you push the start button with out touching the brakes for like 5 seconds.
Old May 1, 2021 | 12:39 PM
Red Mist Rulz's Avatar
Red Mist Rulz
  • Open the door.
  • Shift to Neutral.
That process is described on the owners manual.
Page 198 of the 2021 manual:
To Does the C8 have a maintenance mode?
