Sponsored by: CARiD
ARH C8 headers
Old May 21, 2021 | 10:59 AM
racerx8's Avatar
racerx8
Default ARH C8 headers
Just got my C8 Z51 back from Nick at ARH and they did an awesome job! The ARH C8 headers add power, a louder, more throaty sound and look perfect in the engine bay. It was about a 240 mile ride home and the headers have this awesome light gold/silver color. You can't do any better than ARH, you get performance, a better sound, save a few pounds, clean up the engine bay and get a great looking set of headers. Nick, Jose and crew did a great install job Thank you guys! BTW I've used ARH on all my GM trucks, Camaros and Corvettes for years, quite simply they are the BEST!
Old May 21, 2021 | 11:41 AM
Kracka's Avatar
Kracka
How does the car feel in comparison?
Old May 21, 2021 | 08:41 PM
racerx8's Avatar
racerx8
Kracka, I'm sure it does make more power, definitely feels better, a bit more responsive. My Z51 only had 610 miles when the ARH's were installed and I'm positive they are a great addition to a great car.
Old May 21, 2021 | 10:23 PM
Kracka's Avatar
Kracka
Sounds great! At the moment I'm torn between ARH & AFE, but the KOOKS are definitely out and I have no internet in the Chinese knock-offs.
Old May 21, 2021 | 10:32 PM
racerx8's Avatar
racerx8
ARH are the best, fitment, quality and price. I can only speak from my experience, that of some friends and my tuner, they all use and recommend ARH.
You'll be very pleased with your choice of ARH headers.
Old May 22, 2021 | 07:36 AM
RDSC8's Avatar
RDSC8
I agrree ARH are yhe only way to go .
Old May 22, 2021 | 01:30 PM
JillyBean's Avatar
JillyBean
What’s the cost for those?^^^
Old May 22, 2021 | 04:44 PM
racerx8's Avatar
racerx8
The list on the ARH C8 headers is $2073.75. The cost to install can vary with your shop but I'd say $500 to $700 would be the range, you can do it yourself the ARH install instructions are very good.
Old May 23, 2021 | 09:48 AM
langhorne_bill's Avatar
langhorne_bill
Active Streak: 90 Days
I plan on installing the ARH headers with stock cats and mufflers when my C8 Z51 coupe is delivered sometime this summer whenever BG ends their various shutdowns. I like a good exhaust note around town, but on long trips prefer a quiet interior; my C6 Z51 does quite well in the noise department with Z06 headers and ‘mild to wild’ switch on the NPP mufflers.
Do the C8 ARH headers drone at highway speeds? Is the interior noise level much higher than stock while cruising and windows up?
Thanks, Bill
Old May 23, 2021 | 11:40 AM
RDSC8's Avatar
RDSC8
Thanks, Bill
No drone or excess noise.
With the stock cats & muffler u probably wont notice any change.
Install was ~$500.00 at my shop>
Old May 24, 2021 | 09:41 AM
ZaXxon's Avatar
ZaXxon
1-7/8" or 2", which did yall go with? I assume you only need 2" for forced induction.......
NEVERMIND, just read the ARH post stating 1-7/8" is the way to go.
Old May 24, 2021 | 01:15 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Awesome! We have some 1 7/8 on order..
-Josh
Old Jun 9, 2021 | 07:52 PM
CP's Avatar
CP
Thanks, Bill
Doesn't this kind of defeat the purpose of adding headers?
Old Jun 11, 2021 | 10:34 PM
Ragtop 99's Avatar
Ragtop 99
Not at all. It still improving the exhaust gas flow compared to the stock manifolds. The C8 stock cats are not a huge restriction. Even the most expensive brands are only seeing about 6 HP from a cat swap.
Old Jun 14, 2021 | 07:33 PM
Langang's Avatar
Langang
Except for Soul Cats..
Old Jun 15, 2021 | 02:11 PM
Ragtop 99's Avatar
Ragtop 99
^^^Their cats are good, but has anyone replicated those gains on another dyno?
Old Jul 7, 2021 | 02:40 PM
ZaXxon's Avatar
ZaXxon
Default Headers Installed!
Installed my ARH 1-7/8" headers over the holiday weekend. Fantastic quality, perfect fitment. They even came with gaskets and manifold hardware. I happened to be installing an AGW high wing at the same time, so I already had the back bumper off. Even without doing a wing install, I would highly recommend removing the rear bumper when doing this install. A lift also helps.
Just finished the install yesterday and went on a short cruise. Very noticeable sound difference when on the throttle, but very tame at normal cruising speed. Love them so far.
One other note, I ordered ARP stainless studs for the manifolds but ended up not using them. You can't get the headers installed with the studs installed (at least the way I was doing it), so it defeats the purpose. ARH included some nice quality 10.9 grade hardware (similar strength to grade 8) that I used with nickel based anti-seize.
Stock cats and cat back BTW
To ARH C8 headers
Old Jul 10, 2021 | 09:23 AM
langhorne_bill
Great Job! One question - does a normal 7/8 (22mm) O2 sensor socket work OK? Is that socket deep enough and have a wide enough side cut out for the wires?
Thanks, Bill
Old Jul 11, 2021 | 12:32 AM
ZaXxon's Avatar
ZaXxon
Originally Posted by langhorne_bill;[url=tel:1603710077
1603710077]Great Job! One question - does a normal 7/8 (22mm) O2 sensor socket work OK? Is that socket deep enough and have a wide enough side cut out for the wires?
Thanks, Bill
Yes. I used a cheapo harbor freight O2 socket.
The trick is you have to cut the little zip ties that secure the heat shielding on the O2 wires. This allows you to pull back the heat shielding while using the socket. The heat shielding slides right back in place when done.
Old Jul 11, 2021 | 09:42 AM
wallyj's Avatar
wallyj
Do you recommend removing the bumper for access or to reduce how far over you have to lean to get to the exhaust?
