Sponsored by: CARiD
DCT shifting pattern
Old Jul 31, 2021 | 04:42 PM
range96's Avatar
range96
Default DCT shifting pattern
Let's say you're cruising 70 mph in 8th gear and all of the sudden you floor the accelerator while the transmission is in automatic mode. Does the DCT shift down to 3rd gear immediately? (Haven't driven a C8 yet, couldn't find an answer in search).
Old Aug 1, 2021 | 08:28 AM
thrilled's Avatar
thrilled
I imagine it will go down a few gears, What I don’t like if you have it in manual mode is that you have to flip it each time to go down a gear,
Would have liked to skip flips with the flipper but I guess I’m asking way to much
Old Aug 1, 2021 | 08:49 AM
JVi's Avatar
JVi
Have not tried this yet but I have read that for downshifting in manual mode, hold down the shift paddle and the system will figure out what gear to select thus avoiding the multiple paddle taps.
On page 201 of the 2021 owner's manual it says:
To cause the transmission to downshift to the lowest gear possible for the vehicle speed, in Manual Paddle Shift or Temporary Manual Paddle Shift mode:
Pull and briefly
hold the paddle. If the paddle continues to be held as the vehicle slows, downshifts will continue as vehicle speed allows.
The Manual Paddle Shift system will not allow an upshift or a downshift if vehicle speed is too fast or too slow, nor will it allow a start from any gear other than 1 (First) gear.
In the end, I believe that the Automatic mode reacts faster.
Old Aug 1, 2021 | 03:33 PM
BJ67's Avatar
BJ67
Most likely not, especially in a Z51 car. You will be close to the max mph in 3rd gear, and as you floor the throttle at 70, the car will start to accelerate before getting into the the lowest possible gear and instantly you will be too close to max speed in third gear approx 83 in a z51 versus 88 in a non Z51 car. You should be able to manually bring it down to 3rd at 70 mph or just pull the left paddle and hold it for a second it should drop right into 3rd gear from 70MPH.
Old Aug 1, 2021 | 10:23 PM
range96's Avatar
range96
So, what gear will it shift down from 8? Is it 3rd, 5th, 7th? Can someone confirm? I didn't think it can shift into 4th from 8 (even gears share the same output shaft).
Old Aug 2, 2021 | 08:26 AM
BJ67's Avatar
BJ67
I can only hope it should go right into 4th at that speed from 8th on a wot stab.
Old Aug 2, 2021 | 08:40 AM
Rapidblux2's Avatar
Rapidblux2
It’s best to drive I’m track mode no paddles at all and study the learned shift points . Then you can work on paddling with proper rpm locations which comes with a plethora of good things. Like safety and dct longevity.
Old Aug 2, 2021 | 08:55 AM
BJ67's Avatar
BJ67
Does the DCT really learn shift pattern in track mode? like upshifting sooner etc for every day street driving? I tried track mode but only for a minute or two on a few occasions, its just too aggressive and holds each gear at a way to high rpm for normal street use.
Old Aug 2, 2021 | 06:57 PM
range96's Avatar
range96
I'm surprised no one has experienced this:
cruising 70 mph in 8th gear and all of the sudden you floor the accelerator while the transmission is in automatic mode (track mode or any other mode). What gear the DCT shifts into?
Old Aug 3, 2021 | 10:03 PM
gbf_98070's Avatar
gbf_98070
Track mode is designed to be used on a track. In D / track mode the transmission wants to shift at about 5500 to 6000 rpm and at WOT. If you want civilized behavior use Sport or Tour (My Mode is just Tour mode. Sport is just tour mode with different shift points.) If you want to drive in track mode and control the shift points drive in M.
Old Aug 4, 2021 | 09:04 AM
BJ67's Avatar
BJ67
Thank You, My main objective is to stay out of V4 mode, but there really is not a easy way. Driving in track mode or manual mode doesnt cut it. I am tempted to try a ranger that is used on the Camaro's. I understand tuners have limited access to the ecm, is there any access to the V4 mode tables??
Old Aug 4, 2021 | 09:14 AM
gbf_98070's Avatar
gbf_98070
I usually drive in M unless I am in Z-Mode, which I have set to track for engine/transmission. That works for me, but if you want to drive in D and not in track, and not in V4 then you are in an operational regime that the car was not designed for. Tuners don't have access to the PCM at this time as I understand it, but I think that may be evolving.
Old Aug 4, 2021 | 09:23 AM
BJ67's Avatar
BJ67
On the Camaro and the C7 , isnt the V4 mode tables access thru the normal tuning tables thru the ecm?
Old Aug 4, 2021 | 09:26 AM
gbf_98070's Avatar
gbf_98070
I'm not the expert, but as I understand it the C8 tables are encrypted and nobody has cracked the code yet.
Old Aug 4, 2021 | 09:54 AM
BJ67's Avatar
BJ67
a few well known tuners have had C8s hooked up and there is limited info seen, but what is adjustable if anything I do not know.
Old Aug 5, 2021 | 08:46 PM
gbf_98070's Avatar
gbf_98070
Here's an article from today's general discussion on tuner access.
https://www.corvetteforum.com/forums...-c8-s-ecu.html
Old Aug 5, 2021 | 09:13 PM
BJ67's Avatar
BJ67
Has any one plugged in a ranger for a camaro 10 speed car into the OBDII port of a C8 to see if it stops V4 mode?
To DCT shifting pattern
Old Aug 5, 2021 | 10:44 PM
Racer X's Avatar
Racer X
I have not done this test yet, but was able to do a different test 55 in 6th, it dropped immediately to 3rd gear. I was in touring mode. I will try to do it in 8th at 70. I wonder if you were at 70 in 7th (sport or track mode maybe, would it drop to 3rd or 4th because it should shift from an odd to and even gear otherwise it would be a longer shift.
Certainly an interesting question.
Old Aug 6, 2021 | 01:52 PM
Racer X's Avatar
Racer X
OK, today I was in touring mode at 60 in 8th, and I floored it. It dropped directly to 3rd. AT 58? in 7th, it dropped to 4th, then quickly shifted to 3rd.
So it appears it drops to to the lowest gear that is on the other shaft, then goes back to original gearset at an even lower gear. This makes since as it is the fast way to execute the shift. It certainly shifts faster from 7th to 4th to 3rd than I could shift from 7th to 3rd in a manual.
I have not tried in manual mode and holding the downshift lever to see how low and quick that would occur. Maybe someone else can try it.
Old Aug 6, 2021 | 08:29 PM
WalterSobchak's Avatar
WalterSobchak
Goes into 3rd. Only difference in Track vs Sport is Track in D keeps you in 6th as the highest gear vs 8 in Sport. It's more instantaneous in Track but it's quick in Sport going from 8 to 3 as well. You can do the old the left paddle to 3 from 8 as well but you better be ready to hit the right one because you'll be at Redline quickly in 3 at 70ish.
This is completely false. First, Track mode in regards to the transmission is shifting algorithms ones you can mimic with the paddles. The only reason it's not recommend on the street is if you enter the PTM modes and degrade your nanny protection. Second Track mode in D shifts you right at 6500 under WOT.
