Sponsored by: CARiD
Introducing the Fabspeed Performance Package
Old Sep 7, 2021 | 11:25 AM
Fabspeed_Motorsport's Avatar
Fabspeed_Motorsport
Supporting Vendor
Default Introducing the Fabspeed Performance Package
Introducing the first complete C8 performance package in the industry! Truly the best way to fully transform your new Vette into a whole different beast!
This complete exhaust solution for the C8 will absolutely wake up the LT2 V8! You’ll be treated to more power across the rev range, huge weight savings, and best of all an intoxicating exhaust note. Choose between our Valvetronic or Supersport cat-back exhausts and add header blankets for any performance-driven vehicle where engine bay temperatures are a concern.
INCLUDES:
SOUND:
With a total revamp of the exhaust system, your C8 will have a brutal exhaust note. You’ll feel the american V8 rumble in your chest at idle and with the valves open it will absolutely rip to redline. With the valves closed the system is still loud but is liveable around town and you can easily hold a conversation in the cabin (valvetronic exhaust only).
FEATURES:
  • Fits all Chevrolet Corvette C8 mid-engine Vehicles Coupes and Convertibles worldwide 2020+
  • CAD designed and CAD flow developed
  • Incrementally dyno developed for maximum power
  • Constructed from T304L stainless steel
  • Significantly improves power and throttle response
  • HJS trimetallic catalytic converters imported from Germany
  • Heat blankets are rated to 2200 degrees fahrenheit and significantly reduce engine bay heat
  • Saves -47 lbs / 21.3 KGs with the Supersport Exhaust and -29 lbs / 13.2 KGs with the Valvetronic Exhaust compared to the factory exhaust
  • Valvetronic exhaust has plug and play valves for seamless functionality
  • Valvetronic exhaust uses aerospace quality Helical Limited exhaust valves imported from the U.K.
  • Includes AFM valve simulator mounts - Fabspeed recommends placing the car in 8-cylinder mode to eliminate any possibility of a Check Engine Light
  • Headers feature mandrel bent runners and indy car style 4-1 merge collectors for maximum flow and power
  • No CEL guaranteed
  • Simple “bolt-on” installation
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
Old Sep 14, 2021 | 04:38 PM
Fabspeed_Motorsport
Supporting Vendor
Ride along in a 2020 C8 Corvette equipped with our Headers with Heat Blankets, Sport Cats with Heat Blankets, and Supersport (non-valved) cat-back exhaust system. This system will NOT trigger a check engine light.
Old Oct 4, 2021 | 11:56 PM
DNDN's Avatar
DNDN
8th Gear
Default sound
Sounds very good........
Old Oct 5, 2021 | 10:20 AM
Fabspeed_Motorsport
Supporting Vendor
Need an aggressive stance to compliment your sound?
KW suspensions, the premiere high-performance coilover suspension manufacturer based in Germany, has developed the first in the market fully adjustable coilover suspension kit for the new 2020 Chevrolet C8 Corvette Stingray. The redesigned iconic American Sports car comes packed with 6.2L LT2 V8 engine neatly nestled between the passenger cabin and rear axle marking the first time a mid-engine Corvette has been released for production. The reconfigured vehicle was built to sit lower and handle even better than its legacy vehicles before it. So of course, KW suspensions set out to push the new C8 Corvette’s performance even further with the addition of their Variant 3 Coilovers.
To Introducing the Fabspeed Performance Package
