Sponsored by: CARiD
Engine Noise Question
Old Sep 12, 2021 | 09:38 AM
flycapt's Avatar
flycapt
1st Gear
Default Engine Noise Question
My engine makes a rapid ticking noise. It is especially noticeable at low speeds and in Z-Mode. My Corvette Specialist service tech said "it's normal" and that all C8's have the same noise. I'm not satisfied with his response. Considering he said "all C8's have the same noise" I wanted to get some feedback from this group. Are you experiencing the same? Thank you
Old Sep 12, 2021 | 03:25 PM
Kracka's Avatar
Kracka
Yup, these engines have noisy valvetrains; similar with the C7's LT1. Especially as V4 mode activates & deactivates.
I had my C7 for 7 years & 56k miles; the C8 LT2 sounds exactly the same in terms of valvetrain & DI injector noise.
Old Sep 12, 2021 | 09:40 PM
BJ67's Avatar
BJ67
I would have to hear what your hearing, I hear nothing unusual and I hear everything. What your hearing while driving should not be, what you hear with the engine running , while you listen with the rear hatch open is a different thing. You may hear a injector tick or what sounds like a little rocker arm chatter, or a fuel pump tick, should not be audible while driving. I have had 2 C7's, and also have a 2021 camaro LT1, no unusual engine sounds while driving.
Old Sep 13, 2021 | 11:11 AM
RKCRLR's Avatar
RKCRLR
The engine does have a ticking noise from the direct injection and this is normal.
Having said that, my C7 had a rattling noise. I brought it to the dealer and was told that the noise was normal. The "normal" noise progressively got worse. Turned out the belt tensioner was bad.
Old Sep 13, 2021 | 11:41 AM
Kracka's Avatar
Kracka
This was rather common in 2014's. The tensioner was revised for 2015.
Old Sep 14, 2021 | 01:37 PM
RKCRLR's Avatar
RKCRLR
Actually, I had a 2015. And it went out again after a few years.
Old Dec 1, 2022 | 07:12 PM
rcws6's Avatar
rcws6
Cruise-In IV Veteran
Glad to see this thread. I was going to start a new thread, I always do a search first. I put in ticking sound for the description and hear I am! So that’s what mine does, odd thing is when it goes to V4 mode the ticking stops. I don’t recall the sound at lower mileage (currently has 2800), but I’ll follow this post for other folks experience. Loving the car, hard to believe I’ve had it for 8 months. I split seat time between the C8 and my 02 mill. Yellow C5.
Old Dec 1, 2022 | 07:14 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I’m not satisfied with his response lol 😆
I wouldn’t work on corvettes for a living for any amount of money 💰
Old Dec 1, 2022 | 08:44 PM
RKCRLR's Avatar
RKCRLR
I haven't noticed the ticking noise reduced when in V4 mode. Your noise may be different than the typical direct injection tick - its hard to tell by written descriptions. If a lifter was bad it could explain why the ticking goes away in V4 mode. Or perhaps it is normal for the injector load being reduced in V4 mode. It may be worth you asking about it during your next service visit.
Old Dec 1, 2022 | 11:10 PM
rcws6's Avatar
rcws6
I’ll have to pay real close attention. I know it’s more noticeable in V8 mode. I’m going to do the first oil change here in the next couple of weeks. I normally service my own cars. I’ll take advantage of the oil change and trans filter change later on.
Old Dec 2, 2022 | 12:22 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
There have been lots of posts in various threads here about the ticking noise. It is the fuel injectors. Also, easier to hear in the coupe than the HTC - the layer over the engine seems to block some of the noise. Anyway, the tech is right - all C8's do it. Some people are able to hear it better than others.
Old Dec 2, 2022 | 08:30 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep, started with the C7s and direct injection. Unlike port injection you're squirting gasoline into the combustion chamber that has high air pressure when the piston is near TDC. That and the fine mist needed use ~3000 psi fuel going to the injectors. In V4 mode 4 cylinder injectors are no operating so perhaps that is a reason it is more in V8 mode.
With the C7 they also had sound insulation under the intake manifold to reduce noise from the high pressure pump. In some cases the insulation was not fully around the perimeter and made the noise worse. Don't recall that was a common issue.
I don't hear any ticking. In fairness my high pitch sound hearing is not great AND I have my sound system playing when the car starts to drown out the tire and road noise. It's a sports car. Certainly no ticking as with sold lifter performance cams!
Old Dec 3, 2022 | 10:14 AM
MikeinAZ's Avatar
MikeinAZ
I get a ticking when it switches to v4 mode and I'm over 60mph. Does not do it at lower speeds or in 8 cyl mode.
Tech said they can put it on a lift and run it at speed and manually shut down each cylinder and see if they can reproduce the noise. May have them look at it one day, after having the engine removed recently and dealing with all that, I just want to enjoy the car for a bit.
Old Dec 3, 2022 | 06:58 PM
dohabandit's Avatar
dohabandit
Mine sounds like an old singer sewing machine. The ticking is the DI injectors.
Old Dec 7, 2022 | 02:39 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is certainly not what we like to hear, rcws6. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: rcws6/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Dec 8, 2022 | 12:41 AM
MarkMeHopeful
So much for @Chevy Cust SVC. They didn't read the posts to see that this is a normal condition we're talking about. I've seen this here before. Why do they even bother?
To Engine Noise Question
