Sponsored by: CARiD
93 octane?
Old Sep 17, 2021 | 02:37 AM
E TKIT RIDE's Avatar
E TKIT RIDE
Default 93 octane?
The book says use 93 but I know of only 91 octane gas unless you go to AV gas which is too high.
Anyone have a solution? It says perf may be affected. Is anyone adding octane boost to each tank?
Old Sep 17, 2021 | 10:45 AM
JVi's Avatar
JVi
Page 226 of the owner's manual for 2021 says:
If unavailable, unleaded gasoline with a posted octane rating of 91 may be used, but with reduced performance and fuel economy.
Page 227:
Fuel containing metals such as methylcyclopentadienyl manganese tricarbonyl (MMT), which can damage the emissions control system and spark plugs.
I use STP non MMT octane booster (do not use the STP MMT based octane booster - it has the MMT written right on the bottle).
Old Sep 17, 2021 | 12:15 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Just be aware that many octane boosters that claim to raise octane by some number of "points", a point is 1/10 of, an octane number. Thus tend to be lots of money for not much increase.
Old Sep 17, 2021 | 12:53 PM
Kracka's Avatar
Kracka
Add 2 gallons of E85 per tanks and presto, 93-octane!
Old Sep 17, 2021 | 02:15 PM
BJ67's Avatar
BJ67
Hey Kracka, has there been anyone that you know of that has done a dyno pull to see if by adding E85 to 91 or 93 would net a power increase? that would be nice to know. I realize this would have to be done in small quantities like you say 2 gal per tank, because ya cannot run high concentrations of E85 with out a sensor and a tune.
Old Sep 17, 2021 | 04:18 PM
E TKIT RIDE
@Kracka but the book say no E85???? Cant anything just be simple..of course not. Then you gotta worry about MMT as well... may just end up using 91 octane and say F*** it.
Old Sep 17, 2021 | 05:25 PM
Kracka's Avatar
Kracka
"No E85" as in straight E85 since that's [up to] 85% ethanol and 15% gasoline (you need a FlexFuel vehicle to run straight E85), rather than the standard fuel with is 85-90% gasoline and 10-15% ethanol. Blending 2 gals of E85 into a tank of 91 (which is an E0 product ) makes the equivalent of 93 (which is E10). Adding 10% ethanol to 91 E0 is how 93 E10 is created. Depending on the region, this is done at the rack or blender level, and again depending on the region, is sometimes unavailable to local retailers and C-stores.
It truly is that simple
I have a handy dandy spreadsheet to help you calculate it exactly down to the decimal places if anyone would like a copy of it.
Old Sep 17, 2021 | 05:27 PM
Kracka's Avatar
Kracka
There is a noticeable seat-of-the-pants difference in both the C7 & C8 running 93 vs. 91, especially in the heat of summer. I've run just about all the various options and methods available while living elsewhere, roadtripping cross-country, tuning cars, etc.
Old Sep 17, 2021 | 09:30 PM
BJ67's Avatar
BJ67
I certainly believe you, I didnt know 91 octane had no E in it, Here in Connecticut the pumps just say contains 10 % ethanal and always thought that was for all the gas.. 87, 89, 91 and 93. What happens if you add a couple of gallons to a tank of 93 octane, I know it raises the octane, but does the extra E make more power? E alone makes more power as long as you have a sensor and the car is tuned for it.
Old Sep 17, 2021 | 11:14 PM
Kracka's Avatar
Kracka
Most modern engines can handle about 40% ethanol before throwing a code due to running out of fuel injector. Will blending additional ethanol into 93 E10 made more power? Yes, IF the engine is tuned for it. Going above 93-octane in an engine designed for 93-octane will not have a benefit unless you're in high-temp conditions and you need the additional octane as a knock quench (which ethanol is very effective at). For street use, if you're already using 93 E10 there's no need to add additional ethanol/octane unless you just want the headroom because to plan to really beat on the car in high temps (in which case, splash blending in a gallon sure wouldn't hurt). I know when it's 100F+, car loaded down with luggage, AC blasting... I can feel the ECU pulling timing even with 93 E10 when I really start pushing the car. That's the time a little extra headroom is beneficial.
Old Sep 18, 2021 | 08:16 AM
BJ67's Avatar
BJ67
That is exactly my theory on how octane really prevents power loss by reducing spark knock tendencies in heated conditions. Back to E85, does E85 compared to 93 octane if all else is equal (no change in timing) produce more power on its own due to its content? Or does additional amounts of E85 fuel have to be tuned into the system for that via the E85 tuning tables and again leaving timing alone.
Old Sep 19, 2021 | 02:35 AM
GettnBetter's Avatar
GettnBetter
Lo@93 octane. Who's cocktail are you promoting and what does it offer?
Old Sep 19, 2021 | 01:21 PM
TJay74's Avatar
TJay74
Some of you are confusing octanes. Depending on where in the USA you are you will have 91 E0 or 93 E0, or 91 E10 or 93 E10. There can be some fuel contamination with even 91/93 E0 to where it shows to have Ethanol in it.
With that the C8 and C7 fuel tank is 18.5 gallons, you can run up to E15 (15% Ethanol) easily with no issues, so on the ninitial fill add 2-3 gallons of E85 to the tank of 91 or even 93 and fill the rest up with 100 E0 gasoline. From there you just need to adjust how much Ethanol you add back in at each fill up. I always put Ethanol in 1st, then add the Ethanol fuel 1st, then add the gasoline to help mix it inside of the tank.
Old Sep 19, 2021 | 02:58 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
OK, Yada Yada Yada on the no MMT in your car, been running it from almost day one in my bolt on 17 C7 Z06, purchased November of 2016. I get plenty of life out of my spark plugs, and after 5 years of running Torco in EVERY single tankfull, pretty sure I'm on the original O2s...
I don't give a hoot about the Naysayers, I've been running Torco for almost 15 years, not a single issue! If running MMT concerns you, please do what makes you comfortable, and I'll continue to do what works for me...
https://youtu.be/q2n88MjiGpM
https://youtu.be/qyEQxighdco
Old Sep 19, 2021 | 06:10 PM
Racer X's Avatar
Racer X
I love the color of the car.
Old Sep 19, 2021 | 09:15 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Thanks BRO, hoping they come out with a very similar color on the C8 Z06, I've had a deposit on one for almost 2 years...
Old Sep 20, 2021 | 10:51 AM
E TKIT RIDE
Default E85 mix
@Kracka Thanks for the help brother... I'll look around for E85 fuel and try your mix solution.. Where I live, only 91 is available so looks like it would be my only option. I have a tank of 91 in now with 370 miles on my car. I noticed a little pinging yesterday, very slight but I could hear it. Also have noticed the ticking sound some owners have described prior to an engine failure. Mine seems to go away once I get about 30-40 mph so hopefully it is normal. The car seems to run awesome so fingers crossed I got a good one! Thanks again for your insight - I saw some of the engine mods you did, impressive stuff.
To 93 octane?
Old Sep 20, 2021 | 11:48 AM
Kracka's Avatar
Kracka
Thank you! I'm loving how the car feels so far, and yes, I noticed some pinging in mine the few times I've run straight 91 as well (my C7 was actually even worse, that car flat out ran like crap on 91). I'm somewhere around 5,800 miles on the C8 now and enjoying every bit of it.
Old Sep 27, 2021 | 10:35 AM
SSWIM's Avatar
SSWIM
Where one lives dictates the Octane also. I am at 5000 feet and 91 is just fine. 93 would be a waste of money. At sea level I would opt for 93.
Sam
Old Sep 27, 2021 | 01:24 PM
RKCRLR's Avatar
RKCRLR
It's interesting that the 2022 owner's manual now calls out the minimum octane as 91 with no mention about 93 octane.
The direct injection was tweaked for 2022 but it was stated that was for better mileage and smoother idle.
