Sponsored by: CARiD
QuickJack Assembly Issues
Old Dec 29, 2021 | 09:31 AM
langhorne_bill's Avatar
langhorne_bill
Active Streak: 90 Days
Default QuickJack Assembly Issues
I just put together my QuickJack and had trouble connecting the hydraulic couplers. I was able to get the intermediate hose connector to close and lock by hand. However, the hydraulic couplers at the power head required brute force with pliers to rotate the knurled lock into the locked position. I was able to fire the unit up without leaks,but wonder about ever being able to easily use the couplers in the future. Has anyone else had issues with difficult coupler connection?
Thanks, Bill
Old Dec 29, 2021 | 10:16 AM
Bburr's Avatar
Bburr
It was a little tricky for me as well. Knowing that it takes an extra push to get it on. The trick to remove it is to grab the collar and pull back on it and the hose at the same time.
Old Dec 29, 2021 | 10:27 AM
mwestc5's Avatar
mwestc5
Thanks, Bill
You need to depressurize the unit
Once it's powered up, hold the DOWN button for 5 seconds-
That should do it
No need to remove any hydraulic fluid
It's a good idea to do that periodically when lift is extended and in lock position and before lowering the lift:
Hold the DOWN button for 5 seconds
That will make it easier to connect hoses next time
Old Dec 29, 2021 | 04:21 PM
langhorne_bill
The unit was de-pressurized as I had never turned it on. The quick fittings are much stiffer than those on my John Deere 6400 which uses a different design.
Bill
Old Dec 31, 2021 | 09:02 PM
Caymanspyder's Avatar
Caymanspyder
Very simple trick, Plug the power in, as stated simply press the down button and they connect with ease.
Old Jan 1, 2022 | 10:41 AM
langhorne_bill
Thanks! I will try this the next time I use it.
Bill
Old Jan 1, 2022 | 04:22 PM
TomT's Avatar
TomT
I had the same hard time connecting hoses. In my case, it just took determination and dumb brute force.
Old Jan 2, 2022 | 02:46 PM
dfettero's Avatar
dfettero
ALso , be sure the valve on the pressure unit is open to allow pressure to escape.
To QuickJack Assembly Issues
