Sponsored by: CARiD
PDR Dash Cam
Old Mar 4, 2022 | 06:26 PM
JGSPORT's Avatar
JGSPORT
Cruising
Default PDR Dash Cam
Can the C8 PDR be set up to record as an automatic (no other intervention) dash-cam whenever driving the car?
Old Mar 4, 2022 | 08:09 PM
BryanKlingele's Avatar
BryanKlingele
Modified C8 of the Year 2021 Finalist
No it can't is only powered when the car is powered on.
Old Mar 5, 2022 | 04:27 PM
JGSPORT's Avatar
JGSPORT
Cruising
I added "whenever driving the car".
Old Mar 6, 2022 | 12:40 PM
Addoni67's Avatar
Addoni67
6th Gear
I have mine set to record everytime the car is running. Only issue is there is no rear cam as far as PDR. So for the front, yes it can be used as a dash cam. I've been looking for a small rear one for my HTC, but for a coupe it shouldn't be a problem.
Old Mar 6, 2022 | 04:36 PM
mavio's Avatar
mavio
Yes. I have mine set to start when ever I start the car. See manual for instructions.
Old Mar 18, 2022 | 08:45 PM
ladder13's Avatar
ladder13
Anyone recommend a longer duration replacement for the factory card?
Old Mar 18, 2022 | 10:01 PM
BryanKlingele
I used a 512G ScanDisk extreme and make sure it's Class 10 for the video
Old Mar 18, 2022 | 11:01 PM
Kracka's Avatar
Kracka
There is no factory card, you have to add your own.
I use a PNY 64GB.
Old Mar 28, 2022 | 01:52 PM
Bob Paris's Avatar
Bob Paris
SanDisk 256GB Extreme PRO SDXC UHS-I Card - C10, U3, V30, 4K UHD, SD Card - SDSDXXY-256G-GN4IN (Under $56 from the eminent source)
To PDR Dash Cam
