NPP valve always open trial
Valves are controlled by pulse width modulated signals, but only have two commanded positions - full open and full closed. The difference I and others have noticed in each drive mode are because the valves move between these two positions at different times depending on the drive mode.
I assume the valves move fairly quickly because there is a lot more motion commanded than I had realized.
The position of the NPP valves are also affected by the commanded position of the AFM valves.
And here is the full document:
2022 Chevrolet Corvette | Corvette Service Manual 15356649 | Engine / Propulsion | Exhaust | Description and Operation | Document ID: 5830642
Exhaust Tail Pipe Flow Control System Description and Operation
Engine Exhaust Flow Control Valve System
The engine exhaust flow control valve system Has two subsystems:
1. The exhaust tail pipe flow control valve system, also known as the exhaust sound quality valve control system.
2. The cylinder deactivation exhaust flow control valve system, also known as the active fuel management (AFM) exhaust flow valve control system.
Exhaust Tailpipe Flow Control Valve System
The exhaust tailpipe flow control system is used to tune the exhaust note for high performance vehicles. The vehicle is equipped with two tailpipe exhaust valves, one in the left tailpipe and one in the right tailpipe. Each exhaust tailpipe valve is installed in the low restriction exhaust path of a dual outlet muffler, near the exhaust tip.
When a tailpipe exhaust valve is open, the low restriction exhaust path is opened to the atmosphere, and the exhaust note becomes more aggressive.
An output circuit from the fuel pump control module is used to control the actuator that opens the left and right exhaust tailpipe valves. The exhaust flow control valve open and closes when the fuel pump control module commands the actuator by pulse width modulation of the control signal.
To provide a more aggressive exhaust note when the vehicle is started, the exhaust tailpipe valves are opened during an engine crank event during specific mode of operation if that option is available. Once the engine is running, accelerator pedal position, transmission gear, and engine speed are used to determine the commanded state (open or closed) of the exhaust tailpipe valves.
There are four specific exhaust performance modes that result in different behavior of the exhaust tailpipe valves. These modes follow:
Note: You may notice the exhaust tone change due to the AFM system activation, or due to certain driving conditions to meet Federal noise pass-by Regulations. Review the cylinder deactivation exhaust flow control system operational modes listed below for additional details.
1. Winter/Eco Mode: Exhaust tailpipe valves will be closed at all times when the engine is running.
2. Tour Mode: Exhaust tailpipe valves are closed when the engine is idling and during normal/non-aggressive driving. Valves open during aggressive driving.
3. Sport Mode: Exhaust tailpipe valves are open when the engine is idling and during most driving scenarios. See note above.
4. Track Mode: exhaust tailpipe valves are open at all times. See note above.
It is possible to personalize the exhaust sound. When engine sound enhancement is turned off via the personalization menu, the exhaust tailpipe valves will be put in track mode no matter which vehicle mode (Winter/Eco, Tour, Sport, or Track) is displayed on the driver’s instrument panel.
Cylinder Deactivation Exhaust Flow Control Valve System
As a means to improve fuel economy, the engine management systems in some vehicle applications include provisions to deactivate half of the engine cylinders under certain operating conditions. For example, under a light load. The cylinder deactivation exhaust flow control valve subsystem is used to mitigate the impact of that powertrain engine cylinder deactivation (active fuel management) has on the quality of the exhaust sound. When the active fuel management system is operating, the exhaust tailpipe flow control valves are commanded shut resulting in a quieter exhaust note until the active fuel management system deactivates with increased throttle demand at which time the exhaust tailpipe flow control returns to the operational status determined by the vehicle specific mode that is being used.
The cylinder deactivation exhaust flow control system controls the undesirable exhaust noise generated during the cylinder deactivation process. This is accomplished by the use of two electronically actuated cylinder deactivation flow control valves in the vehicle exhaust system. The cylinder deactivation exhaust flow control valves are commanded to the closed position by a pulse width modulated signal from the fuel pump control module.in response to active or pending cylinder deactivation. When the cylinder deactivation exhaust flow control valves are in the closed position, the engine exhaust flows through a hole machined in the plates integral to the valves. When the engine is operating an all cylinders, the cylinder deactivation exhaust flow control valves are commanded to the open position in order to minimize exhaust restrictions. To provide some control hysteresis, once the cylinder exhaust flow control valves have been commanded to the closed position, they are not reopened until the engine torque reaches a calibrated minimum value that is determined as a function of the driver selectable performance mode.
In the C7, the V4/V8 valves (prior to the muffler) sent signals back to the computer and would trip a CEL if the valves did not close when commanded by the computer. The C7 NPP valves did not! That is why pulling the NPP motor fuse (using a switch or remote relay like Mild to Wild) to bypass the fuse- worked! Now the C8 NPP valves send signals back to the computer!
Solution is to install bypass devices like PHASTEK sells (see pic) that trick the computer OR as I said worth trying: SEE PIC, Disconnect the motor to valve connection and keep the motor plugged in. Just like the skip shift delete on manual C7's the computer will think the motor "did its job!"
The difference in having a "switch" as I installed for my C6 NPP, is when flipped you can hear the sound difference. As you note all that will happen at Moderate Throttle is it will sound like what you found! " but did sound more aggressive when driving away at slower rpms."
At partial throttle that is all you can get with reduced exhaust flow. IMO your comments show some proof that, as expected and as happened with the C7, Although the Service and Owner's Manual may say the NPP valves are "always" open in Track Mode THEY ARE NOT ALL THE TIME! At low rpm they shut! The rpm that occurs is dependent on Drive Mode.
What you are finding is what folks who tried removing just that side of the 3-prong fuse that activates NPP (easy to do just short that section) with the FUSE REMOVED- TRIPPED CEL.
PS: The louder Cold Start Sound is also due to the richer air/fule mixture and higher idle that MOST cars use. Many cars sound louder at starts and don't have NPP! Including what C8 owners have posted of their non NPP cars!
These work like the C6 and C7 manual trans to defeat "Skip Shift." The computer thinks the NPP motor closed the valves and "did its job" but didn't! ~$119.
This Is Why Cold Starts Are So Damn Loud
A cold start can turn a humble hatch into a roaring monster truck, and something more powerful like a V8 Mustang can send shivers down your spine. Revel in the power (and the glares from the neighbours) for those few seconds, until the car starts idling normally again and you can set off.
To start with, a car’s ECU decides that the engine has to idle higher when the engine is cold to stop it from stalling. This is programmed into the ECU via a start-up map, which allows a richer air/fuel mixture to enter the cylinders. Ideally, efficient combustion occurs at a higher temperature than that of the ambient temperature of a cold engine, where the fuel can vaporize naturally and be burned.
When it is cold, more fuel is added to the air/fuel mixture to make up for the lack of natural vaporization. So the AFR (air-fuel ratio) is seen by the ECU to be leaner than usual (below the Stoichiometric ratio of 14.7:1) so it compensates for this with extra fuel to make up for the unburned fuel due to the cold.
Although it might wake up your neighbours in the morning – especially when coupled with a lack of exhaust-silencing – a cold start-up function within the ECU is a necessity in this day and age, seeing as we have abandoned the choke as a mechanical device. The cold starts can surely put a smile on the face of any true petrolhead, whatever the weather.
In the C6 no drive modes to change sound BUT I installed a simple switch to bypass the NPP fuse. I kept it open most of the time but at highway speeds there was an objectional drown and I had to flip the switch and allow NPP valves to close.
We just had a poster say "it was louder at lower rpm's with NPP's disconnected. BUT like Thomas, some may need to insert their hand in the wound! As I said, we really need a way to turn on or off OR someone with a fiberoptic camera to look!
Don't have data on the C8 but what you describe would be easy to show in the C7. In Touring the NPP valves opened at about 2500 rpm. In Track (or as I and many did when NPP set to always Track) they opened at about 1700 rpm. So if driving at 2000 rpm and changing drive mode from Touring to Track it would get louder!
As I said until it can be switched to hear the change there will always be folks who won't agree. Lasted for several years with the C7 and some even with posters saying it changed with Mild to Wide some would still quote the "book!"
Frankly it's so much quieter in my C8 coupe than even 2014 C7 or 2017 Grant Sport, perhaps I would not here much!
