Dodson trans oil fill kit installed
Don't forget if your using a lift don't block the undertray bolts. Ask me how I know lol.
The OLM / DIC doesn't update when you are tracking. Have to keep track of that yourself.
Great pics of the install!BTW, you are not the only one who blocked the two bolts on either side of the rear Aluminum Shear Plate/Aero Panel.
I made this Pic to show how the Tech who removed mine was able to use my 1-inch high GM spec (max 2 1/2 inch diameter) lift pads to clear the 4 bolts using a hand wrench to remove (versus other bolts where he used his powered wrench.)
Top Pic is dealer tech removing my aluminum shear plate/aero panel using my 1-inch-high GM spec'd (max 2 1/2-inch diameter lift pads.
Bottom Pic is Chuck at the dealership where Conti is a salesman saying they had to lift a C8 several times, so their jack pads on their lift arms cleared the 4 bolts!
I did a similar setup with a banjo bolt to AN fitting and installed it under the airbox. Now I have a remote fill location with easy access in the engine bay. I hook up my pump and in a few minutes the trans can be filled. I also added in a M14x1.50 Valvomax drain in the drain location. Since I track my car and will need to change fluid yearly, this will make the entire process really easy. Oh, I added in the "trap door" mod into the pan as well... super easy going forward.
Now building a remote fill for the level plug hole side gearbox. Same braided lines and anodised hardware with M20 x 1.5 to AN8 plug and lines.
Essen@BrookeK did the same as I.
I used an M14 x 1.5 to AN6 banjo:
I pointed this to the "outside" (passenger side here in the US), so my airbox has an extra wall cut vs. the picture shown above.
Next I added this AN6 18" with a right angle hose:
From there I can just take this hose directly up to the cross member. My goal was to be able to use my pressure tank to fill the car, and that came with a series of adapters:
At the end of the 18" hose I placed this adapter: AN6 / M12 x 1.5
This allows me to use the ATF109 adapter which is M12 x 1.5
If you notice though, I now have threads on both ends. Finding an female / female M12 x 1.5 piece seemed VERY expensive for some reason. Then I realized that you can get open end wheel lug nuts in M12 x 1.5, so I did that for a few bucks.
So, for everyday, the banjo bolt -> 18" AN hose -> this cap
I use this AN6 cap:
And it just resides in the car. When it's time to fill, I remove the cap, and I attach my ATF109 + the open ended lug nut and I can fill the system in about 10 mins. It worked flawlessly, and I was rather happy with coming up with this.
I'll get a picture soon of the hose and setup as the pictures I have right now are mainly for mock up and rough. They worked for me to work through making cuts and such without any real issues though.
Mine is a 2022 model so can safely add up to 2 more qts ( if tracking) so dont really need to check via fill hole.
If worried and wish to be exact when the first drain is done measure out the dirty oil
