Sponsored by: CARiD
TPMS Questions
Old May 27, 2022 | 09:51 AM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
Default TPMS Questions
Has anyone had good results using Non-GM TPMS sensors?
Also are there any differences between the 2021 and 2022 sensors? I'm seeing conflicting information.
I'm selling my 2021 wheels and tires to someone with a 2022 and hoping there wont be any issues..
Thanks!
Old May 27, 2022 | 06:24 PM
GoNDeep11's Avatar
GoNDeep11
Just from many many years of experience, never use any other TPMS besides GM and the sensors are the same, I've had a 21 C8 and a 22 and have swapped wheels from both cars...
As far as the TPMS my buddy owns a very large volume tire shop here in Scottsdale and he said aftermarket are nothing but issues...
Old May 27, 2022 | 06:33 PM
pettvette's Avatar
pettvette
Thanks for responding. There seems to be a shortage of the factory tpms is why i considered the aftermarket. I did go to my local chevy dealer this afternoon and ordered 3 sensors and nuts, they had one in stock.. I called 8 other dealers, none avalible.
While at the dealer they checked the 21-22 part numbers, both the same.. they had three fresh 22's on the lot, used the vin from one of those to check.
Old May 27, 2022 | 08:16 PM
bhvrdr's Avatar
bhvrdr
In stock at rockauto for 28 bucks
Old May 28, 2022 | 05:16 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
I have 3 sets of wheels for my 2021 Z51. The OEM sensors are not expensive, and the reset tool is cheap too. VERY easy to re-learn each set of wheels. Don't be cheap.
Old May 28, 2022 | 05:22 PM
Zoomtt's Avatar
Zoomtt
My 22 has the xxx760 GM TPMS sensor. Worked well
Old May 28, 2022 | 08:53 PM
bhvrdr's Avatar
bhvrdr
Must be an optical illusion but sure looks close on a broomstick test
To TPMS Questions
