C8 FEL not working after lowering
I have recently lowered my C8 with both the stiffer / lower Paragon springs and the lowering collars (plus shim) - total 1 3/8" drop. The Front End lift is not working and the dealer is saying it's because the FEL level sensor is below the minimum threshold. Anyone else had this issue / does this make sense ? Once I get the car back I'm going to shim the sensor up and see if I can "trick" the sensor into working, but seems like thats something they could have done... They are also unable to align it.... as it won't fit on their rack... so if any one in the SF Bay Area has a recommendation for a dealer / performance shop that works / understands C8's modifications and does track alignment I'd love a recommendation....
