Sponsored by: CARiD
Fan stays on
Old Oct 3, 2022 | 07:16 PM
Detvetboy's Avatar
Detvetboy
8th Gear
Default Fan stays on
I just added a Haltech cold air intake. After running it a little hard it seems that the fan stays on about 10 to 15 minutes after shutting off the car the temp was only at 205 max. Is this normal or is there something that needs to be done
Old Oct 3, 2022 | 09:53 PM
Kracka's Avatar
Kracka
Did you plug the temp sensor on the airbox back in?
Old Oct 4, 2022 | 04:50 AM
Tim0shel's Avatar
Tim0shel
Mine does this sometimes and random but this is without installing said Haltech intake. Think it is something the car should normally. I think if it was something to be concerned about etc you would be seeing some error on the dash.
Old Oct 4, 2022 | 08:49 AM
Kracka's Avatar
Kracka
To elaborate a bit more, installing my aFe intake made no meaningful change in the way the engine bay fan runs at shutdown. Even with headers and cats on the hottest TX summer days, my fan will typically only run for a minute or two after a hot shutdown.
One test you could do is raising the "hood" after a hot shutdown to see if that aids in cool down and reduces fan run-time.
Old Oct 5, 2022 | 12:54 AM
MillerTimeISU's Avatar
MillerTimeISU
I have headers, Halltech Hornet Intake, ported TB, ported Intake Manifold, and Paragon exhaust and never had fans stay off even when pulling inside with temps in the 190's-200's.
Old Oct 5, 2022 | 08:37 AM
c5racr1's Avatar
c5racr1
my fan stays on a while after a 20 minute track session. I guess I depends on how hard you were running.
To Fan stays on
