Hey guys, I am looking for a tire option that is zero pressure. Are there any out there for a 20/21 setup? I just really do not like the idea of not having a spare--likely not having a local option to get a quick replacement tire--and being stranded quickly with a flat. I want to find a run flat option if at all available that would work with this setup, otherwise I am thinking I will go back to a 19/20 wheel and tire option.
Our cars come factory with run flats correct, which is a 19/20 size setup. I have a 20/21 setup on mine and which do not have run flats. I have been looking and cannot find any in a size that would work.
What are you guys running this setup doing as far as backup on a flat? Could you even comfortably take the car on a trip knowing if you get a flat your screwed?
I’m surprised about the Z06. I bought a Slime Digital Emergency Flat Tire Repair Kit 50123 and threw it in the frunk. Probably not ideal but gave me some peace of mind.
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Good news. Here are the C8 Z06 20/21 run flats you should hopefully be able to source
Michelin Pilot Sport 4S 275/30ZR20 front and 345/25ZR21 rear, high performance, run-flat summer-only tires.
