The install was smooth although the instructions missed a couple of small steps. Getting the couplings in place was tough until I used my heat gun. The only part of the kit I did not like was the seal between the air box and the tube running to the throttle body - I tried A glue gun then ended up using gorilla tape to secure the circular gasket in place.
I am not sure if there is much of a noise difference but after about 30 minutes of start and stop under partial throttle I tried A few launches and seemed to gain some extra push at the higher rpm. I will Dyno before and after I add The Fab Four exhaust but unfortunately have no base number.
