Weight Reduction- Carbon Fiber
It would be interesting how much weight you can shed by replacing fenders, hood, hatch with carbon fiber.
Granted, this approximation assumes equal panel thicknesses, but as a first shot, it’ll get one into the ballpark.
First thought the density of later C7 panels was down to 1.1 with addition of micro hollow glass beads. Know Moldered Fiberglass (who made the 1st '53 Vettes) and makes a few parts for the C8, supplies a few composite parts for the C8 that floats i. e. <1.
Carbon fiber can be as low as 1.5 (70% cloth/30% resin) to 1.9 BUT is very strong and panels can be much thinner. It's panel thickness not density that makes it lighter. But agree would look elsewhere for weight redaction, including removing interior insulation, racing seats, replacing the rear inner coupe window that is twice the thickness of the windshield to reduce noise etc. Thin Lexan is light and strong.
As others have said, wheels, titanium exhaust would be the first to consider.
PS: Found this re C8 Materials: The low-density but structural SMC panels feature new formulations (in this case, 40% FVF chopped fiberglass/unsaturated polyester (UP) resin) developed by MFG. The material is called “float” SMC because each panel’s density is less than 1.0 (average SG=0.97) and thus can float in water.
The new Corvette features not one but two trunks that, combined, hold 12.6 cubic-feet/0.36 cubic meters of cargo. Both trunks are produced in 42 wt-% chopped fiberglass/vinyl ester-unsaturated polyester (VE-UP) resin, but use different processes driven by geometry and mechanical requirements. The front trunk (frunk) is compression molded 0.95-specific gravity (SG) “float” sheet molding compound (SMC), while the rear trunk is formed via the proprietary PRiME (Prepositioned Reinforcement ensuring Manufacturing Excellence) process, a liquid compression molding (LCM) variant. The float SMC and the PRiME process were developed by processor Molded Fiber Glass Co. (MFG, Ashtabula, Ohio, U.S.). MFG produced all structural SMC and LCM’d parts on the car.
*Dry carbon - matte finish
*Autoclave process with 3K, 2x2 twill carbon fiber cloth, matte finish
*Our DRY carbon does not have UV protection, it is recommended to have it coated with an automotive grade clear coat with UV inhibitors if you do not plan to paint or wrap the part
*This is a carbon fiber roof replacement
*Bolt on, mounts with OE hardware
*Does not include weather stripping or related hardware, must transfer from OEM roof
*Professional installation highly recommended
*Hand crafted; approximate weight 7.6 lbs. (OE weight is 15.7 lbs.
I'm keying in on that part where it says that their dry carbon roof does not include any weather stripping or related hardware. I'm guessing that is how they arrive at an 8 pound weight savings whereas the OEM on get 1.5. That, and there is no clear coat on it. I also assume it is probably just a wafer-thin piece of carbon not even finished on the underside like the OEM roof is. All this goes to say that, given my brief research, this seems like an inane way to attempt to reduce the weight of your C8.
Not bashing Anderson Composites in any way, they definitely have a niche product they are bringing to market that looks to be high quality. On the upside, at about $2,800, the dry carbon roof panel is probably a couple of hundred cheaper than the OEM carbon roof at your local parts counter.
I’ve owned a good bit of Seibon. All great quality. But have heard other stories of slight misalignments of panels.
Anderson seems to make great parts from what I’ve seen on a few Mustangs. I’m sure the weight saving claims are a little biased. For example: The C8 dry CF hatch has a claim of approximately 23.7lbs in savings. So when there’s no clear description and the pictures show no glass or even Lexan. I then assume the claims with their hatch is a dry weight without transferring glass and other materials. Take it there is still savings in weight and on the top end of the car but it’s a high price to pay.
