Sponsored by: CARiD
Transmission problem
Old Jan 19, 2023 | 09:07 AM
jotee's Avatar
jotee
Default Transmission problem
P park button occasionally doesn’t release when putting in great have to pound on console to release park this just happened
Old Jan 19, 2023 | 01:18 PM
clegg's Avatar
clegg
There is possibly a loose wiring connector, unfortunately you will have to take it into the dealer.
Old Jan 19, 2023 | 04:17 PM
Andybump's Avatar
Andybump
Is "great" supposed to be "gear"? I can't quite tell what you are saying. If you pull the park button, the car goes into park. If you are in park, and pull the drive or reverse button, the car should exit park and go into forward, or reverse. Are you saying that when you pull the drive or reverse button the car stays in park?
If so, and pounding the console helps, that does sound like a connection or switch problem. Or is the button actually physically stuck? In another thread, someone said they put some sort of decorative cover over the gear selection switch (adhesive backed carbon fiber I think) and the cover interfered with the actual motion of the buttons. Is something interfering with the button on yours?
Old Jan 19, 2023 | 04:57 PM
jotee's Avatar
jotee
this has happened a few times otherwise it does not happen
To Transmission problem
