Sponsored by: CARiD
Engine Code P12F7 Advice
Old Jan 21, 2023 | 12:26 PM
rjmayo's Avatar
rjmayo
Default Engine Code P12F7 Advice
Check engine light popped on today on my C8 with performance exhaust. Drove right home and parked and called OnStar. They had some trouble getting the code at first, but after shutting down and leaving the door open for 3 minutes they got it.
Came up as P12F7 - An issue has been detected with the exhaust tailpipe flow control system. This system is used to tune and control the exhaust note for vehicles. If the vehicle is continually driven with this light on the operator will experience exhaust sound performance degradation and abnormal vibration generated from the exhaust system.
It was swapping between V4 and V8 mode like normal on the way home and when I switched between exhaust mode there was an obvious audible change like normal.
I'll get it into service, but how safe is it to drive in the meantime. Can't really find others posting about this code ever being made, especially about a C8. Everything seems normal, but the idea of extra vibrations in the exhaust make me a little worried I could do damage.
Old Jan 21, 2023 | 03:24 PM
Andybump's Avatar
Andybump
Maybe. You have 4 valves back there, 2 AFM valves and 2 tail pipe flow control valves. All the valves are supposed to be open, or shut. The dont have in-between positions. It possible that an actuator is stuck shut. Not all of them, since you can hear a volume change. When the AFM valves are shut, it pretty restrictive - those valves each have a tiny hole that allow exhaust to flow when they are closed, and are meant to be closed only when the car is being driven at a steady speed, in V4 mode where the half the cylinders are deactivates. Seem like if one of those was stuck shut all the time, it could be a potential issue. If a tail pipe flow control valve is stuck shut, thats no a big deal unless you are tracking the car. There is a caution about continuous aggressive driving in stealth mode (which is when the tailpipe flow control valves are mostly closed). The thing is, you don't know if the code means the valve is stuck in one position, or just some issue with the feedback path that monitors the valve positions. So, maybe.
Old Jan 21, 2023 | 05:40 PM
Bill Dearborn's Avatar
Bill Dearborn
If you don't have a state vehicle inspection coming up disconnect the battery and see if the code goes away. Then drive the car for a few days to see if it comes back. If it does I suspect it won't hurt to drive the car to the dealership as it is designed to be driveable on the street/highway with all exhaust valves closed.
Bill
Old Jan 22, 2023 | 12:38 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
I wouldn't worry about driving it. Even if a valve is stuck open or closed it won't do any damage (although if closed I wouldn't advise any wide open throttle or redline operation). If everything seems normal just get the CEL cleared and see if it comes back again. If it does come back, it might just need a valve relearn, which the dealer can easily do. In any case, it won't hurt the car to drive it until you find out what the problem is.
Old Jan 23, 2023 | 08:20 AM
rjmayo's Avatar
rjmayo
I had planned to disconnect the battery the next day, but I went out and started the car later that night and the CEL was gone. Drove it around for a few miles and it didn't come back. Hopefully it was just a fluke and it doesn't come back.
Old Jan 23, 2023 | 01:40 PM
Cicio Performance's Avatar
Cicio Performance
Supporting Vendor
You are perfectly fine to drive the car just fyi even if the code is on.
I know you said it has performance exhaust, do you mean the factory performance exhaust or something aftermarket?
Andrew
__________________
Cicio Performance Website
Old Mar 30, 2023 | 02:03 PM
Sbrennan's Avatar
Sbrennan
Default Same code-GM Borla Exhaust installed
Sorry to hijack this thread but I'm having the same issue. Dealer diag said pretty much the same as is written here (valve issue) but they didn't have a solution except to have it either tuned out or don't worry about it. I'm concerned about both of those suggestions especially since its a GM purchased part that they installed and I can't imagine that either of those are a good course of action. Besides the expected "bring it to the dealer and insist they fix it" has anyone else seen this besides the OP and can give me some ammo/background to use when I chat with them again? As always, thanks in advance
Old Mar 30, 2023 | 02:29 PM
rjmayo's Avatar
rjmayo
Hijack away brother. I've noticed no difference in the car at any point when the CEL is on or off. It will go away sometimes and then come back, always the same code. We're coming out of winter where I'm at so it wasn't driven much. I'm a bit at a loss as what I should do since I got basically the same response from the service department at my local dealership. I can live with the CEL being on if it's not hurting anything, but when I decide to sell the car it will obviously be a headache.
Old Mar 30, 2023 | 03:02 PM
rjmayo's Avatar
rjmayo
Andrew
I never saw this comment, sorry for not responding to your question. It's the factory performance exhaust. I would have been less concerned if it was an aftermarket setup.
Old Mar 30, 2023 | 03:23 PM
Sbrennan's Avatar
Sbrennan
or I wonder if state inspection will also be an issue? Its frustrating that this is a GM part that a dealer installed. Seems to me this should be fixable but what do I know. I'm just a squirrel looking for a nut.
Old Mar 31, 2023 | 08:00 AM
01Defense's Avatar
01Defense
Locate a dealer who has experience with these issues.
Old Mar 31, 2023 | 08:05 AM
DGinLZ's Avatar
DGinLZ
Mine had a similar fault. Dealer replaced a faulty stepper motor / controller on drivers side exhaust.
Old Mar 31, 2023 | 08:48 AM
Andybump's Avatar
Andybump
What does "tuned out" mean? There are procedures that should be performed any time the AFM and tailpipe flow control valves or actuators are messed with. They are "Cylinder Deactivation Exhaust Control Valve Learn." and "Exhaust Control Valve Learn". The first one addresses the AFM valves that are just after the cats at the muffler inlet and the second one addresses the valves in the tailpipe that control the exhaust loudness. If that does not correct the problem - then DTCs point directly to one or more diagnostic procedures for tracking down the problem. Think of it as pointing to the general area where a problem exists. Then by following the indicated diagnostic steps, the tech can pinpoint the issue. And it could be a pinched wire, a damaged actuator, a problem with the valve on the muffler, failure to perform the learn procedure, or something else. Did your dealer perform those diagnostics? If a dealer follows the diagnostics and is unable to solve the problem, they are then supposed to contact GM for engineering help.
Old Mar 31, 2023 | 10:43 AM
Sbrennan's Avatar
Sbrennan
Thanks for the reply (awesome information! ) and by "tuned out" they were suggesting to call the tuner I have gone to before with my C6 and C5 to get some ECU changes made and they could delete that signal/error. I actually challenged that they could even do that based on what I've read about the C8s encryption. But regardless, I think there's agreement that going in that direction doesn't make sense, just took me the ride home to digest what they said and decide that was not the course to go.
I did email the service manager yesterday with the GM bulletin on the relearn procedure and asked if that was done. I await their reply. Your further info is great and much appreciated! I'll call them today if I don't hear back and ask when they want me to bring it in. They are decent folks, I just think they haven't done this kind of stuff before and were a little to dismissive.
To Engine Code P12F7 Advice
