Sponsored by: CARiD
Ported heads on my 2022
Old Jan 30, 2023 | 07:02 PM
64365coupe's Avatar
64365coupe
Default Ported heads on my 2022
Ok. So I decided to put heads on my 2022 z51. Called one of the big CNC head companies and they said no exchange they had brand new CNC’ed castings on the shelf and could ship out the same day. GREAT! Ordered the heads , milled them, thin cosmetics, bolts gaskets ect….. full R&R of the heads. Not easy. Started up immediately. Ran for 5-10 seconds and shut down. Could not figure out why. Too much milling? Thin head gaskets bent valves? 55 lbs compression. Damn. Pulled the heads . No bent valves. Lifters pumped up? Nope. They sold me the wrong heads. In I believe 2022 GM went to a smaller diameter injector and the hole in the cylinder head is approx .040 smaller too. When I fired the car the combustion blew
past the injectors and melted the Teflon seals and the upper white seals to the point there was no more seals left. Gone! Injectors black soot. Trashed. So I call the place and tell them the story and ask what they could do to help me. We will return your money on the heads. That’s it. But I will have to pay the shipping. They will basic Cnc my heads but no shipping. I ask what about all the labor and meltdown parts. Gaskets, bolts now injectors, header gaskets and all the labor involved. Nope. Not their policy…. They admit they sold me the wrong heads though. Anyway. I could try new injector seals from GM. Nope. Back ordered. Well, I’ll just buy new injectors . Nope. Back ordered. Anyway. Does anybody out there know of maybe a set of takeout injectors from a 2022 or 2023 for sale? Maybe from a totaled car?
Old Jan 30, 2023 | 08:31 PM
123sugey's Avatar
123sugey
Dig
That sux. Were you copying someone else’s combo ? Why mill the heads ? You told them you milled the heads and they still stated they sold you the wrong ones ?
Really hope you figure this out asap.
Old Jan 30, 2023 | 08:35 PM
Fore58's Avatar
Fore58
I would give Texas Speed a call.
Old Jan 30, 2023 | 08:40 PM
64365coupe's Avatar
64365coupe
Just trying to bump the compression a bit
Old Jan 30, 2023 | 10:31 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
"Not their policy…." Is that stated on your invoice? And what fine organization is this? Thanks.
Old Jan 31, 2023 | 08:50 AM
Kracka's Avatar
Kracka
Please let us know what vendor this is we the rest of us can avoid them. For the dollar damage done here, you need to press them harder as this is clearly their screw-up; the 2022 fueling changes should not surprise anyone familiar with C8 Corvettes so they should have been well aware of it, especially if they're the ones machining the heads!
Old Jan 31, 2023 | 09:22 AM
c7steve's Avatar
c7steve
give livernois motorsports a call . they did my heads on my 5th gen camaro. back in 2012 I had them mill the heads and they CNC ported them as well. cost was $1100
Old Jan 31, 2023 | 09:59 AM
64365coupe's Avatar
64365coupe
Porting my heads myself. The reason I ordered the Cnc was so my car wouldn’t be down long. Guess that idea is out the door…. 🤨
Old Jan 31, 2023 | 04:42 PM
64365coupe's Avatar
64365coupe
katech
Old Jan 31, 2023 | 05:01 PM
flynnstone's Avatar
flynnstone
Tell them that their negligence cost you $xxxx in damages... Ask them to pay up, or your attorney will contact them
Old Jan 31, 2023 | 05:20 PM
Kracka's Avatar
Kracka
Originally Posted by 64365coupe
katech
WOW! I'd expect them to be the ones NOT to make that mistake, and if they did, properly own up to it! Thank you for the info.
Old Jan 31, 2023 | 07:11 PM
Fore58's Avatar
Fore58
Interesting.....I just viewed their website and didn't see anything in reference to the C8 ported cylinder heads....only the Gen Series. They definitely dropped the ball on this one. There should be a full courtesy reimbursement.
Old Feb 3, 2023 | 01:55 PM
c5racr1's Avatar
c5racr1
lt2 and lt1 heads are the same. seems the later 22 up heads have different diameter HP injectors. I wonder is the 22 up LT1 heads have the same smaller injectors.
Old Feb 5, 2023 | 07:34 PM
64365coupe's Avatar
64365coupe
Old Feb 6, 2023 | 12:30 PM
Ksteckba's Avatar
Ksteckba
katech
Wow, my first ASSumption was that it would be some unknown shady shop, but that is a shocker. Very disappointing!
Old Feb 7, 2023 | 10:04 AM
itsonlyairandfuel
What are the flow number you achieved, compared to stock?
Old Feb 14, 2023 | 07:35 PM
64365coupe's Avatar
64365coupe
Well, After hunting down back ordered injectors and seals , l finally fired up my car. Seems much more crisp. Throttle response. How
much power? I don’t care. If it picks me up 2 or 3 mph and 2 or 3 tenths I will be happy. I’ve had pretty good luck with my 60’ times considering im
running stock street tires. I think drag radials are in the picture next. No check engine lights ! Thanks again Snowblind for all your help!
To Ported heads on my 2022
Old Feb 14, 2023 | 07:50 PM
123sugey's Avatar
123sugey
Dig
If it does pick up 3mph I would be happy as could be even with the headache. Yup it’s a learning experience and I wish you well. Do you have any draggy results you can compare ?
Old Feb 14, 2023 | 08:52 PM
9secGN's Avatar
9secGN
Im sorry this happened to you. But unfortunately that's how the after market goes.
May ask how did you swap the heads. Did you drop the engine or swap from the top. And if so, how did you handle the dry sup tank bolt that goes into the head. That's my only deterrent.
Old Feb 14, 2023 | 09:00 PM
c5racr1's Avatar
c5racr1
he didn't drop the motor, he cut the bolt that goes through the dry sump tank. same thing Im going to do this weekend.
