Sponsored by: CARiD
torque specifications
Old Feb 8, 2023 | 05:44 PM
c5racr1's Avatar
c5racr1
Default torque specifications
anyone know the from end torque specifications? upper, lower ball joint, upper and lower coil over bolts, sway bar end links? rack?
Old Feb 8, 2023 | 10:21 PM
allblackeverything's Avatar
allblackeverything
German spec. Good-n-tight
Old Feb 9, 2023 | 03:05 AM
Ksteckba's Avatar
Ksteckba
*gutentight
Old Feb 9, 2023 | 11:55 AM
Andybump's Avatar
Andybump
I think I found part of what you want. I don't know what coil over bolts and rack refers to. The attached is based on information in the 2020 Corvette Service Manual. Manuals have been known to have errors - so use at your own risk.
Old Feb 9, 2023 | 10:28 PM
Andybump's Avatar
Andybump
I finally figured that coil over is referring to the shock with the spring over it. The upper fasteners are nuts. The lower fastener is a bolt. Once the unit is removed a special tool is required to remove and install the shock rod mounting nut. The information is found in the service manual - there could be errors in the manual - use at your own risk.
Old Feb 11, 2023 | 07:50 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
To torque specifications
