Sponsored by: CARiD
Rear window in C8 HTC
Old Mar 5, 2023 | 12:18 PM
BobbysC8R's Avatar
BobbysC8R
Default Rear window in C8 HTC
My rear window in my 2022 C8 HTC is stuck in the Open position.... Any suggestions.??
I have appt. with dealer next week to bring it in but would like to figure it out before then..
Thanks for your help .....
Old Mar 5, 2023 | 01:41 PM
Racer X's Avatar
Racer X
I have seen any posts on this issue. Never had a problem with mine. My first step would be a reset. Which I think start the car, open the door shut the car off, leave the door open for at least 90 seconds. If that doesn’t work disconnecting the battery for about 90 seconds, then reconnect. You may lose radio station presets. There are tons of computers in today’s cars. Sometimes they need to be rebooted.
Old Mar 5, 2023 | 06:26 PM
BobbysC8R's Avatar
BobbysC8R
Well I tried starting it and leaving the door open when shut off, I disconnected the Battery, I even tore into the fuse box and the fuse is good, I changed it anyway....
Still not working....
Thank you all for the advice...
If you have any other ideas, I am open to hear them...
Again... Thanks..
Old Mar 13, 2023 | 07:53 PM
OKCorvette's Avatar
OKCorvette
Try cycling the HTC top fully down and then fully up with the door shut and running. See if this resets the system.
To Rear window in C8 HTC
