https://www.vehicleservicepros.com/s...sfire-concerns This article, is using narrow band 02 as a basis. Straight from the article. "I began teaching this technique to Ford technicians in the Advanced Drivability courses starting in 2000" That was over 20 years ago.
Reason: spelling
As you can see from the article and Bosch, open loop or closed loop the secondary o2 is not just a cat efficiency monitor as many believe.
It is typical to see the downstream sensor voltage floating in the 350 to 650mV range when the cat is lit off, the system is in closed loop and there are no misfires or other concerns. In fact, most manufacturers monitor the downstream oxygen sensors and will tweak LTFT to improve fuel
I'll amend my statement -- downstream O2 readings do not have a meaningful impact to trims.
I only had drivers side that was throwing code, did use O2 extender and CEL is gone - 500 miles and many starts and CEL is still off, so think the problem is gone - but I too bought them because of "quality and no CEL promise" which in my 22's C8 proved to not be true.....
i just installed the 2M fabrication sport cars on my 2024 C8 Z06 and i have the check engine light on.so you recommend the o2 extender?
Fixed my issues - but many type O2 extenders - get the biggest you can get - I used Fabspeed - as much as I hate to recommend .... but they solved the issue.
Good luck - I know it is maddening -
Thank you so much just the O2 Extender from Fabspeed?
Yes, added the O2 extender on drivers side and CEL and code has not come back - Fabspeed is expensive, but bigger than most and fits - mine was "just a stingray" so not sure on z06
ok so just get 1 not 2? also do i get the 45 degrees or 90 degrees. thanks a lot for the help i appreciate it.
is your code only for drivers side? Forget what code, but it will say what side - hope it is drivers as that was "easy" to get too - I believe the passenger side would require some R&R some parts - drivers was reachable with wrench to just remove O2 and install the extender - don't remember if I had 45 or 90 - might call Fabspeed on Monday and also ask about your engine (thinking for some reason you said Z06) will clear with extenders..... GL
