Sponsored by: CARiD
90 Octane or 93
Old Apr 18, 2023 | 05:13 PM
harley2's Avatar
harley2
Default 90 Octane or 93
Best gas to use on the Z?
90 Octane 100% gas?
93 Octane with 10% ethanol?
Old Apr 18, 2023 | 05:41 PM
yell03's Avatar
yell03
93 octane.
All gas around my way has 10% ethanol.
93 beats 90.
Old Apr 18, 2023 | 06:00 PM
harley2's Avatar
harley2
Some gas here is 91 or 90 octane No E
other gas is 93 Octane 10% E
Old Apr 18, 2023 | 06:17 PM
Kracka's Avatar
Kracka
93 E10, absolutely no question.
Old Apr 18, 2023 | 08:00 PM
Fore58's Avatar
Fore58
That's exactly what works for me. And i get it from Sam's club and BJs. Tried Shell 93V-Power.....didn't make no difference at all.
Old Apr 18, 2023 | 08:29 PM
yell03's Avatar
yell03
I usually run Sunoco 93, sometimes Shell or Wawa 93, all have ethanol.
Sunoco is my preferred fuel, probably from back in the day when there was Sunoco 94.
Old Apr 18, 2023 | 11:30 PM
X25's Avatar
X25
Sr.Random input generator
What matters is the octane rating and the detergents inside. Ethanol is not a bad thing at all. It has a bit less energy density, so fuel with ethanol causes a bit more fuel consumption, but that's it. 10% is not enough to cause any corrosive issues, either.
We only have 92 octane in WA, and my local track sells no ethanol 92 octane. I still always prefer the 10% ethanol mixed fuel and bring my own, since the engine learns and optimizes for the fuel type, and there's no reason to upset it.
In my area, the highest octane fuels are from 76 and Chevron, and I get my fuel from them only. Shell has good detergents, but its octane is a bit less than the others (something I've learned the hard way when I used to tinker with turbo engines).
Old Apr 19, 2023 | 08:30 AM
dhanley's Avatar
dhanley
From what I have read it appears that while the cheaper gas may have the same octane rating and may perform the same, the top tier gas companies have a far better additive package for cleaner combustion etc. I only run top tier fuels for this reason.
Again, just what my research has shown.
Old Apr 19, 2023 | 10:04 AM
Racer X's Avatar
Racer X
The car's fuel system and ECU was designed to accommodate E10. 93 Octane will be better.
If it were car from 60's with no fuel system updates, 90 Octane and back down timing. The ethanol would act as a solvent on certain fuel system components, that were not designed to resist ethanol.
To 90 Octane or 93
