Sponsored by: CARiD
Anyone Using GM MDI 2?
Old Aug 21, 2023 | 03:44 PM
Mitchell_B's Avatar
Mitchell_B
Default Anyone Using GM MDI 2?
Anyone using MDI 2?
Old Aug 21, 2023 | 04:43 PM
mortelec's Avatar
mortelec
I do and it's just a clone from China. Works great just make sure you have a laptop with the minimum specs to run it with Techline Connect. Techline Connect does check you laptop specs before allowing you to connect.
Old Aug 21, 2023 | 06:35 PM
Mitchell_B's Avatar
Mitchell_B
You have to have a subscription with GM to be able to use this?
Old Aug 21, 2023 | 08:52 PM
mortelec's Avatar
mortelec
I pay the $40 per vin to be able to do any programming / reflashing of modules the same that a dealer can do. The diagnostic subscription is pretty expensive so I use a Zurich Pro bidirectional scanner for that.
Old Aug 22, 2023 | 10:40 AM
RKCRLR's Avatar
RKCRLR
If you buy the hard disk with the software already installed do you still need a Techline subscription?
Old Aug 22, 2023 | 11:36 AM
mortelec's Avatar
mortelec
Yes you need it per vin to do programming. Don't buy a mdi with the software installed because it will need to be updated anyway and it's free on the Bosch website.
It's definitely a learning curve you have to purchase the vin credit through AC Delco and then redeem it in Techline Connect.
Old Sep 18, 2023 | 08:48 PM
Mitchell_B's Avatar
Mitchell_B
Can you use the MDI 2 to perform the trans hydraulic system flush?
Old Sep 18, 2023 | 09:08 PM
mortelec's Avatar
mortelec
With the diagnostic subscription you can. It would be a lot cheaper to buy a bidirectional scanner like a Zurich Pro.
Old Nov 13, 2023 | 04:57 PM
StevePi's Avatar
StevePi
3rd Gear
I have a question about this type of scanner. My '23 Corvette had a check engine light and a cheap scanner gave me a trouble code that didn't make any sense. Since it was under warranty I took it to the dealer and they found one of the rear cooling fans had a wire chewed through by I imagine a chipmunk. So I replaced the fan myself and now have another light and the dealer said they thought it was a chewed wire, not the same one, but they didn't have time to find exactly where. Is there some way I can diagnose this myself? Presently a cheap scanner shows a code that will clear for a second then come back. Thanks.
Old Nov 13, 2023 | 05:23 PM
mortelec's Avatar
mortelec
[QUOTE=StevePi;1607235343]I have a question about this type of scanner. My '23 Corvette had a check engine light and a cheap scanner gave me a trouble code that didn't make any sense. Since it was under warranty I took it to the dealer and they found one of the rear cooling fans had a wire chewed through by I imagine a chipmunk. So I replaced the fan myself and now have another light and the dealer said they thought it was a chewed wire, not the same one, but they didn't have time to find exactly where. Is there some way I can diagnose this myself? Presently a cheap scanner shows a code that will clear for a second then come back. Thanks.[/QUOTE
What is the code you are getting?
Old Nov 14, 2023 | 10:11 AM
StevePi's Avatar
StevePi
3rd Gear
[QUOTE=mortelec;1607235419]
Thanks for your reply.
I'm getting C1555, U112A, U112B, U1347, and U1384.
I can't see any wires cut or frayed from the top of the engine. I may take it to a closer dealer to have them look. They made me mad last time because I made an appointment and left it all day and they never got to it. The one yesterday didn't get around to it till 3.
Old Nov 14, 2023 | 06:38 PM
mortelec's Avatar
mortelec
[QUOTE=StevePi;1607237168]
Did you buy this car new or know the exact history of it? These codes are very random and makes me wonder if it's possibly a flood car.
Old Nov 15, 2023 | 07:27 AM
StevePi's Avatar
StevePi
3rd Gear
Bought it new. I'm assuming it's a chewed wire somewhere since that was clearly what caused the light a couple of months ago.
Old Aug 16, 2025 | 12:03 PM
Waelaburezeq's Avatar
Waelaburezeq
Hey mate,
So it costs $40 per each vin and each module reflash? Or only $40 no matter how many modules you will flash?
Secondly, as for diagnostic, you suggest to use other tools instead? I wonder why diagnosing cost on these software!
To Anyone Using GM MDI 2?
