Sponsored by: CARiD
Yay! I smoked a plug wire….
Old Sep 15, 2023 | 09:03 PM
PhoenixM3's Avatar
PhoenixM3
Default Yay! I smoked a plug wire….
I’m the chucklehead who could quite seat the plug wires on two occasions, but I finally got them seated, only to have the wire on cylinder #6 touch the header pipe. It only took about 10 minutes of driving to burn through the insulation, then it was idiot light city on the dash. I recognized the faults from my previous f@ck ups, but the CEL remained lit. I installed the wires, started the car and cleared the persistent P0306 code.
Chevy wanted $42 for a single wire and it wouldn’t be in until Monday, so I bought some slightly longer (about 3”) wires (from O’Reilly) for $52. Of note, the resistance on the OEM plug wires varied between 2150 and 2350 ohms, which I thought odd. The cheap replacements had a much tighter tolerance and measured between 580 and 590 ohms. Lastly, the angle of the wires on the plug side were about 75 degrees vice the 45 degree angle on the OEM wires. The increased angle resulted in pushing the plug wires further from each header pipe.
One last tip for removing and installing plug wires - take off your shoes and climb in the trunk. It helped immensely.
Old Sep 15, 2023 | 09:46 PM
Kracka's Avatar
Kracka
Ouch! That sucks. Sorry for your troubles... But sounds like you maybe got better spark plug wires in the process. Which one's exactly did you buy? I know people swear by the ACDelco wires, but in my experience I don't see how they are anything special compared to many of the performance aftermarket offerings. They are just your typical mass-produced OEM wire that you would find on a truck or anything else.
Old Sep 16, 2023 | 09:18 AM
mortelec's Avatar
mortelec
Why were you changing the plug wires?
Old Sep 16, 2023 | 09:23 AM
Wadejesu's Avatar
Wadejesu
New Dragon Fire 10mm Low Ohm Spark Plug Wire Set For 2020 Chevrolet C8 Corvette | eBay
Old Sep 16, 2023 | 10:32 AM
mortelec's Avatar
mortelec
Throw those right in the garbage.
Old Sep 16, 2023 | 01:22 PM
Wadejesu's Avatar
Wadejesu
Have you tried them?
Old Sep 16, 2023 | 01:53 PM
Kracka's Avatar
Kracka
I believe he installed headers.
Old Sep 16, 2023 | 01:59 PM
mortelec's Avatar
mortelec
Nope and I wouldn't. At least stay with a company that is known fof making ignition parts like Granatelli, MSD, Accell, or OEM. A cheap set of plug wires will fail prematurely.
Old Sep 16, 2023 | 03:40 PM
Kracka's Avatar
Kracka
Not saying they're good or bad, but Summit Racing does sell Dragon Fire plug wires too.
Old Sep 17, 2023 | 08:33 AM
killian96ss's Avatar
killian96ss
The Granatelli wires are high quality. I had them on my C5Z and now on my C8. GM wires averaged 2100 ohms, Granatelli wires averaged 1 ohm.
Old Sep 17, 2023 | 09:04 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I’d be interested to see a dyno/HP tuners comparison with the two sets of wires. It would seem the 1ohm wires would fire hotter than the OEM 2100ohm. Would that be enough to effect the tune or would the ECU correct for it? If the ECU corrects for it then you could argue the differences in resistance were irrelevant (or could you).
Old Sep 17, 2023 | 01:23 PM
Fishfryer527's Avatar
Fishfryer527
I’m guessing if plug wires alone could make any measurable HP then the factory would have at least put them on the Z51 package and charged another $100 to break that 500hp barrier. However, better wires may not degrade or fail as fast as stock wires, but as long as stock wires don’t throw codes for the emissions warranty period, who cares.
Old Sep 17, 2023 | 03:06 PM
PhoenixM3's Avatar
PhoenixM3
Forced to after burning #6’s wire.
Old Sep 17, 2023 | 11:09 PM
22c8z51's Avatar
22c8z51
Would certainly make for good youtube material.
Old Sep 18, 2023 | 09:42 AM
Racer X's Avatar
Racer X
If you are not misfiring, why would plug wires increase HP?
Old Sep 18, 2023 | 02:16 PM
PhoenixM3's Avatar
PhoenixM3
My guess is people believe lower resistance equals greater spark, therefore a more complete combustion and perhaps more power. Me, I went cheap. Time will tell if I need to pay for that one OEM plug wire because the "cheap ones may fail prematurely...."
To Yay! I smoked a plug wire….
