Sponsored by: CARiD
Z06 Caliper Piston Sizes?
Old Nov 1, 2023 | 03:46 PM
gtpvette's Avatar
gtpvette
Default Z06 Caliper Piston Sizes?
Reviewing the specs for the different calipers and have spent a fair amount poking around. I'm looking for the piston sizes for the Z06 calipers. I've found sizes for the Z07 option on the Essex site and I believe they are the same but not sure. Any thoughts? I do know the caliper part numbers are different between Z06 and Z07 as well as rotor sizes.
Z07 are:
Front 30mm, 34mm, 38mm 102
Rear 40mm, 36mm 76
Z51 are:
Front 42mm 84
Rear 38mm 76
Standard
Front 42mm 84
Rear 38mm 76
AP CP9668
Front 27mm, 31mm, 38mm 96
Old Nov 1, 2023 | 08:46 PM
Drew888's Avatar
Drew888
If you’re comparing the piston sizes to determine the mechanical advantage you need to calculate the total area. On opposed piston calipers you only calculate the piston area on one side.
Z07 are:
Rear 40mm, 36mm 76
Z51 are:
Front 42mm 84
Rear 38mm 76
Standard
Front 42mm 84
Rear 38mm 76
AP CP9668
Old May 22, 2024 | 05:52 PM
murffly's Avatar
murffly
I believe that the Z07 package brakes were the larger Zr1 brembo calipers if I'm not mistaken.
Old Aug 18, 2024 | 08:59 PM
Kracka's Avatar
Kracka
*EDIT*
Wrong thread, please delete. Damn auto-scroll...
To Z06 Caliper Piston Sizes?
