Attack Blue Filter
Popular Reply
Save your money!!! You won't notice a thing.
He has a ZO6 now, so I won't be lining up with him too often. lol
The other issue is the designers use that air filters back pressure to work in the crankcase pressure system...see the discussions on the oil can need/don't need. I found some of the comments pretty solid. YOMV.
An interesting study... it is that 1% that concerns me in a very dusty Az environment.
"Traditional cellulose filter media used for air filtration in vehicle engines are characterized by 99.9% filtration efficiency and accuracy above 2–5 µm. The highest engine component wear is caused by dust grains above 1 µm. Filter media with nanofiber additions provide greater filtration efficiency of dust grains below 5 µm."
Experimental Study of Filtration Materials Used in the Car Air Intake - PMC (nih.gov)
If you want the absolute best in filtration though, then I'd go with the nanofiber AttackBlue. You can get this filter as a drop-in replacement for the factory airbox, or in the Halltech intake system. The downsides to this filter are:
- Higher cost vs. the competition
- Requires cleaning every 10k miles
- Replacement suggested at 50k miles
I am also wary of non independent testing...the old oil medium filters always did much better when tested by the maker/seller.
I'd suggest that study above...it is very in depth but this is one of their findings...
"Research shows that filter material characteristics are closely related. Each increase in efficiency and accuracy of intake air filtration reduces engine components wear, but it is related to flow resistance increase in the engine intake system, which reduces its power, and increases need for more frequent filter servicing."
IOW, if you have more air flow you are ingesting more particulate matter...there is no magic way around that.
Now, if you reside in a very wet climate...low dust then perhaps you can reduce the particulate matter intake. If you live in a dry/dusty area like much of the southwest you are getting fine grit into your intake.
On a chevy engine hot rod with a 4 barrel carb It 'consumed' so much dust (popular red oiled filter/factory oiled) that the idle circuit stopped working and it would stall out...the amount of grit was sickening given what had to go down those throats. Went back to conventional paper and they stayed clean.
Results are just the opposite of aFe's testing.
C8 Corvette Air Intake Shootout! K&N vs aFe Power vs Halltech vs Corsa | Paragon Performance - Bing video
Kraka - wondering your thoughts.
*Important note, this is on NA engines, boosted applications are the opposite and respond very favorably to the oiled cotton media.
