Sponsored by: CARiD
Tire widths
Old Apr 4, 2024 | 10:38 AM
C746490's Avatar
C746490
Default Tire widths
How wide of a tire can you run on stock wheels from a 2024 Z51 ?
Old Apr 4, 2024 | 01:08 PM
Semifighter18's Avatar
Semifighter18
According to Tire Rack, you can put a 255 up front and a 325 out back.
Old Apr 5, 2024 | 01:24 PM
Street_Carver's Avatar
Street_Carver
255/325 is the max width according to Michelin's tire sizing guide for PS4S and Cup 2's. I spent months deciding on factory size or up sizing.
I went with factory size due to it being a daily and wanting to keep the run flats(3 nails so far) and with the paragon spacers the car has enough poke. I have a non Z51 car but a concern with a Z51 car is PTM and the ELSD are calibrated specifically for the factory size tire and compound, although going non run flat or Cup 2's or any other track day tire run into the same issue.
What tire are you looking to run?
Old Apr 9, 2024 | 02:26 PM
progtp's Avatar
progtp
I'm surprised they say you can go with a 325 on a stock 11" rear wheel. I thought a 305 was the max?
I'm running a 325 on a 12" wheel.
Old Apr 9, 2024 | 05:42 PM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
2 sizes wider than stock 11", not sure about that one.
I have 325's on my 11.5" and 315's on my other set of 11.5".
Old Apr 9, 2024 | 09:08 PM
gtpvette's Avatar
gtpvette
As am I. 275 on a 9.5 up front.
Old Apr 9, 2024 | 09:09 PM
Semifighter18
If you go to Tire Rack, when you select a tire you can go to the "SPECS" tab and it will tell you the range of wheel widths that the tire will fit on. 325s will fit on 11" wheels. You can put 345s on a 12" wheel. I did it on my ZL1 1LE.
Old Apr 11, 2024 | 03:23 AM
Turboalky's Avatar
Turboalky
Aerolarri has a 21x13 345/25r21 rear fitment. Looks very interesting 🤔
To Tire widths
