Sponsored by: CARiD
Normal operating temperature
Old Apr 15, 2024 | 03:10 PM
my yellow c8's Avatar
my yellow c8
Default Normal operating temperature
What would be considered the normal operating temperature of a 1LT without the benefit of the Z51 extra radiator in an 88 degree ambient day? I am running about 198 to 199 at 30-40 MPH. Stopped at a light temp rises to 203 to 205 that's engine, oil temp and tranny temp.
Old Apr 15, 2024 | 08:12 PM
X25's Avatar
X25
Sr.Random input generator
Those temps are perfectly fine. The car is pretty robust as long as it's at or below 220s, and starts significantly pulling timing above that. If it's like C7, the limp mode should be around 260 degrees F coolant, and 325 degrees F oil, but you'd not get anywhere close to those levels at the street, unless there's a problem with the cooling system of course..
Old Apr 16, 2024 | 02:24 PM
my yellow c8
I appreciate the feedback. My 2LT always ran cooler but I bought a 2024 1LT and noticed the difference. Thanks again.
To Normal operating temperature
