From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
I've had my HJS Cats now over 3 years, they match up perfect with my headers and the Z51 performance NPP exhaust. Fabspeed and Soul believe are the largest sellers of these Cats today. These high quality 200 cell Kevlar wrapped Cats never have thrown me a CEL, they are pricey but in my opinion worth it and second to none.
Same experience with my Corsas, but yes, the HJS 200-cells will ultimately outflow my 400-cell GESi G-Sport S-Wound cores. I took a slightly different approach and had my cats ceramic coated to match my aFe headers; engine bay temps remain consistently cooler than they were when stock. I'm still happy with my setup 2+ years later
The larger 6" stock cats out performed the higher flowing but smaller 4" performance cats. Hats off to GM for building a great cat.
Granted they didn't name the cat manufacturer so it's left to interpretation. I haven't seen anyone do a comparison that wasn't trying to sell you their product so I honestly don't know. I can state what they have done with my other cars though. Question is if anyone dynoed before and after on a C8.
4.0" is a small-ish core at our power levels, and I think Paragon was (past tense) the only legitimate shop actually using a core that size on the C8. My guess is ARH was attempting to use the same generic 200-cell (see my earlier comment above) they used on their C7 header systems. C7 cats are much more restrictive compared to the C8's (partly because of the inlet flange design), so you could still see gains using the cheap generic 4.0" cores (C7 also had four cats from the factory vs. the C8's two).
What did your car gain with your exhaust modifications? dyno or track times? What did you use to monitor engine bay temperatures? I have only installed a soler t body and socal ported intake so far. Trying gather useful data. Thanks.
Same oven thermometer I used to measure trunk temps before/after adding the additional thermal barrier. It's also obvious based on how the after-run cooling fan operates after engine shutdown (especially during TX summers).
I'm > +30whp (DynoJet) vs. stock at this point, which includes all my mods, not just hot side. I haven't dyno'd since adding the Borla, but I'm due to get back on.
Driving my car vs. stock is night & day, both in my eyes, and those who own the stock cars. Headers were the single biggest power adder. Overall response and increase in top-end pull is notable. The LT1/LT2 is a total dog above 5k RPM in stock form.
so this begs the question what cat Configuration wont throwing a CEO light and will equal the same flow rate as a straight ~3 inch pipe?
For example, if the stock is 700 cell per square inch, and we want to go to a 350 cells per square inch what’s the increase in cat core diameter required ?
