Sponsored by: CARiD
Z51 questions
Old May 3, 2024 | 07:18 AM
GT3 RS's Avatar
GT3 RS
Default Z51 questions
I saw that the Z51 package comes with a bag of Tupperware in the boot. SA said track use only. Really? Does it reduce the clearance that much? And how hard is it to put on and take off? I have a lift.
Old May 3, 2024 | 07:32 AM
Dan Hintz's Avatar
Dan Hintz
The Tupperware is ductwork for the rear brakes. GM suggests not installing it except for track use to reduce the amount of debris aimed right at the rotors. It's not a clearance issue.
Old May 3, 2024 | 08:50 AM
JVi's Avatar
JVi
You can put in the upper half permanently and never worry about ground clearance as it does not change that way.
Old May 3, 2024 | 10:19 AM
RKCRLR's Avatar
RKCRLR
The OP didn't say how many pieces were in the bag. There are 8 pieces total (2 front ducts, 2 rear hub pieces, and 4 halves that mount to the rear lower A arms) and some fasteners. Everything but the 4 halves that mount to the lower A arms are supposed to be installed during PDI but some dealers can't follow instructions and install everything or nothing.
If the rear A arm ducts are left on during street use they can direct debris into the brakes. There has been at least one report of a brake fire attributed to this. Many track rats only remove the lower half of the A arm ducts during street use. The lower halves are easy to remove and reinstall once you raise the car enough to get at them.
Old May 3, 2024 | 06:28 PM
GT3 RS's Avatar
GT3 RS
Thanks everybody. Hope to pick it up next week in Nashua. I will ping MacMulkin and ask if they have that done. Once broken it it will see track time.
So this ductwork can cause a fire from street use? This is just GM trying to keep up with Porsche. Not that many years ago that Porsche pioneered the self igniting engine in the 2014 GT3s, shortly followed by the self destructing engines a few years later.
Its all good, thanks.
Scruffy
Old May 4, 2024 | 10:10 AM
MKC8's Avatar
MKC8
There are some youtube vids out there on how to do it. Dealer, if they read/follow the PDI Checklist, will know what to install (fronts) and not to install (rears).
Fronts are 4 X 10mm bolts and one pushpin (per side), On a lift, would be easy.
Old May 4, 2024 | 12:26 PM
mikegr's Avatar
mikegr
I leave the rear ducts on 100% of the time but drive limited amount on street and normally not in bad weather. No issues to date.
To Z51 questions
