Track Car/ LT2 Engine Woes
For my car and my driving this is a issue. Serious engine load especially on deceleration doesn't allow this engine to breath properly with the crank case being sealed and depending on ring control and scavenge pumps to really keep up. No. It needs to vent up to the valley and become more equal. First my engine failed compression/ leak down test.
Compression
1) 145 2) 145
3) 165 4) 165
5) 165 6) 165
7) 165 8) 165
Leak down
1) 37% 2) 37%
3) 15% 4) 15%
5) 15% 6) 15%
7) 15% 8) 15%
Cylinder walls looked flawless though. Come to find out from LME from the testing they have done for FI builds on their engine dyno testing found quickly that this motor has crank case issues with breathing correctly. Unknown the issues is applying to my NA engine that is pushed hard. Also it is being seen in other shops where rear seals are letting go. Even from cars that do serious spirited drives like the Tail of the Dragon and such. But staying on a straight line with my build I went to a heads, cam, E85 setup while I was replacing the first rear seal. Why not. Shortly after that rear seal again. Most likely quicker this time from the new power, not to mention the leak down results that turn. This is what lead to the deep search.
So the circumstances is LME was already installing vent tubes from the crankcase to the valley (along with another benefit) on their short block builds regardless to resolve this issue so we can vent to a catch can like normal. Lingenfelter has done the same on their new 427. So it's known out there. Not having this causes all sorts of imbalance of pressure causing ring flutter and who knows what else. My new plans could of been just go with a new rebuilt 377 short block that solves my issues from LME. So using my block being it's still in great shape itself I'm moving to a LME Blueprinted and balanced 416 NA 12.5:1, w/ CID's, custom cam and a few more new upgrades from several shops on board.
I feel a lot better knowing I'll have a well built motor in every way for the future. Straight and narrow with great power for the track/ road course. I want to stress this is what we saw, experienced, and concluded with my setup and scenario. Build is in process.
I had a rear main seal failure on my 2024 Z06 track car, 3100+ street miles no problem, 60 track miles and failure.
Lingenfelter
LME
Not that it pertains to this issue. Lingenfelter 427 stroker kit uses a particular crank design for clearance within the oil pan.
My 416 from LME will have a CNC oil pan for clearance. And it is beautifully designed with increased oiling functions.
Some oil needs to pool there so there is something to scavenge.
I received my LME NA 416 long block after waiting for some time after ordering, it made 700hp without boost.
It also kept making power all the way to 8k RPMs on the engine dyno, hopefully that TCM unlock is around the corner..???
LME 416 NA or FI block? Being you mentioned before boost. Yes the TCM will help a lot with pressure control and deleting pressure codes that are sensitive at times. So much win will be coming being it keeps building power.
I’ve been beating on it for just over two years on the track and hard enough on the street. Combined with the stock tune for so long it’s not surprising. I was just hoping for at least three years in some way or form. No different than most other cars that track a lot. On the track with constant acceleration and braking plays havoc on the engine in so many ways. I never had heat issues though. But tracking is brutal on a motor.
There’s so much that can be crossed referenced. Even the flywheel was bad. Did that cause a problem and how long had it been that way. It drove great. But I was always down on power a little. Found out today the ring lands were failing was the issue. So I’m sure over time more pressure was leaking through.
I am now worried about engine damage. Is this something Chevy would cover?
gm anticipates a certain amount of blowby, and sized the scavenging system to accommodate it.
because it is actively scavenging vs all the previous passive / hybrid systems, there is not as much grey area
once you go outside of that (especially if changing things that make blowby) you can be in trouble fast
our c8 systems have the ability to pressure release just like the previous corvette build-outs, but because the top side is sealed off, you just can't help it out that much by adding vents to it, until you mod the valley
